Question: Soldering vs. ProPress Coupling for Dirt Magnet and Air Eliminator
Hi everyone,
I'm in the final stages of my project and could use some advice. I bought a dirt magnet and an air eliminator that have the same type of connection, and I'm trying to figure out whether I should use a copper coupling and solder (weld) it in, or if I should go with a ProPress coupling instead.
The challenge is that the dirt magnet has some plastic components inside, so I'm worried that using heat for soldering might cause the plastic to melt. I also have welding couplings and elbows on hand, but I'm not sure if that's the best choice in this case.
What would you recommend? Should I risk soldering, or is using ProPress the safer and better option here?
Thanks for the help!
cd3888060dfc91ad46207224bb570b5e80671cd5-1.jpg 0d74358c59a51fefc1d41a8c28e272ff1e0b5967-1.jpg ea4718436582babd7f0f8eaa5515df4d52b60267-1.jpg
    mattmia2 Member Posts: 17,451
    edited November 2024
    I removed the innards and sweat it but if i had it to do over again i would have bought the npt version so i could just sweat adapters on to the pipe instead of sweating that body which absorbs a lot of heat.
    those are sweat socket fittings so you will have to sweat to the discal and dirtmag.
    Mad Dog_2delcrossvjoseluisheating
    pecmsg Member Posts: 7,272
    what do the install instructions say.
    joseluisheatingPRR
    joseluisheating
  • Ironman
    Ironman Member Posts: 7,926
    Those are sweat sockets: you have to solder them.
    I’d use low temp silver bearing solder. There’s no need to disassemble it if you know how to properly sweat pipe. If not, I’d return it and get one that’s threaded or one with press fittings.
    Bob Boan
    joseluisheatingmattmia2Mad Dog_2GroundUp
  • delcrossv
    delcrossv Member Posts: 2,204
    Still gotta be quick and focused, but it helps.
    joseluisheating
    hot_rod Member Posts: 27,812
    The composite media inside is far enough away from the brass body, so you can soft solder, around 456°F with no problem.
    I would not silver braze, around 1100°F, on the body, however
    joseluisheatingMad Dog_2
  • joseluisheating
    joseluisheating Member Posts: 53
    Thanks @mattmia2 @pecmsg @Mad Dog_2 @Ironman @delcrossv @hot_rod for you comments of help, I really appreciate.
    I understand that I need to solder these parts. I'll use low heat and keep the flame at a greater distance to avoid overheating. I'll also make sure to keep the flame as far away from the body as possible. Additionally, I’ll use cooling gel to cool down the body part immediately after soldering. I plan to do this for both the dirt magnet and the air eliminator.
    Thanks so much guys, I am in my last step to finish the system. It would be very hard without all you! I appreciate a lot
    Mad Dog_2
    The gel is to stop heat migration while soldering. you can do the same thing with placement of a wet rag. In the case of that housing i don't think there is a lot either would do without making it difficult to heat the joint. To cool it after just wrap a wet rag around it or spray it with water if you want to cool it faster.
    Mad Dog_2Ironman
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,671
    Nice, cold wet rag wrapped around the body. Don't cook it...When the solder flows, that's hot enough. Keep your flame moving to heat all equally. Mad Dog
    delcrossv
