single pipe ticking sound at start of heating cycle
Hello,
I live in a 2 story+basement residential house. I hear maybe 10-20 seconds of ticking shortly after the start of a heating cycle. It's not particularly loud, but I wonder if it is trying to tell me something… I hear it in a my basement, in the vicinity of 2 risers - not sure which it is… All the exposed pipes in the basement are insulated.. One of the riser goes through the ground floor uninsulated to a second the second floor radiator. The other riser goes to the first floor and directly into a radiator.
Thanks for reading!
The expanding pipe is rubbing against wood …
Sounds like expansion noises.
Is this a new house for you? Or is it a new sound from a system you've lived with for several years?
If you can find where it is really coming from, you might be able to get rid of it assuming it is bothersome by placing a plastic (cut from a milk jug) shim between the pipe and whatever.
Ahh… pipe rubbing against…something. House is ~ 120 years old, I've been in it for ~ 22 of them…I've noticed it for past several years…maybe longer. I will try to wedge wedge plastic shims where risers move through floor - if I can't find source, I'm guessing its not a serious issue?
- 50 Industry Classes
