single pipe ticking sound at start of heating cycle
Hipape
Hipape Member Posts: 17
Hello,
I live in a 2 story+basement residential house. I hear maybe 10-20 seconds of ticking shortly after the start of a heating cycle. It's not particularly loud, but I wonder if it is trying to tell me something… I hear it in a my basement, in the vicinity of 2 risers - not sure which it is… All the exposed pipes in the basement are insulated.. One of the riser goes through the ground floor uninsulated to a second the second floor radiator. The other riser goes to the first floor and directly into a radiator.
Thanks for reading!
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    The expanding pipe is rubbing against wood …
  • delcrossv
    delcrossv Member Posts: 2,204
    Sounds like expansion noises.
    Is this a new house for you? Or is it a new sound from a system you've lived with for several years?
    Jamie Hall Member Posts: 27,395
    If you can find where it is really coming from, you might be able to get rid of it assuming it is bothersome by placing a plastic (cut from a milk jug) shim between the pipe and whatever.
  • Hipape
    Ahh… pipe rubbing against…something. House is ~ 120 years old, I've been in it for ~ 22 of them…I've noticed it for past several years…maybe longer. I will try to wedge wedge plastic shims where risers move through floor - if I can't find source, I'm guessing its not a serious issue?
