Should I replace this broken pressure gauge?
What should I order to replace?
See 3 photos below
  • delcrossv
    delcrossv Member Posts: 2,189
    edited November 2024
    Yes, its a code requirement.
    Useless for diagnostic purposes. For that you need to ADD a 0-3 psi gauge.
    Oh, you also need a water trap or pigtail before your new gauge.{s}
    Mad Dog_2
    Jamie Hall Member Posts: 26,832
    Are you sure it's broken? Or just out of adjustment. It probably won't show the low pressures normally used anyway.
  • CoachBoilermaker
    CoachBoilermaker Member Posts: 432
    Not sure.
    I just assumed since someone wrote "Broken" on it.
    I will watch the gauge when the heat runs.
    Steam pressure is generally 1-2 PSI ?
    HVACNUT Member Posts: 7,228
    Is there a direct replacement for that, or will a new gauge need a pigtail?
  • luketheplumber
    luketheplumber Member Posts: 160
    Alot of them I see are broken. I don't worry about them on steam boilers.
    Located in durham NC.
  • Waher
    Waher Member Posts: 364
    Replace it with a 0-30psi “internal siphon” steam gauge. “Internal siphon” on a steam gauge means the gauge has a built in pigtail inside the workings of the gauge so you can screw it directly into the boiler (with dope or Teflon tape)
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,509
    Just write fixed on it. All will be okay
    ethicalpauldelcrossvMad Dog_2EdTheHeaterMan
  • CoachBoilermaker
    Jamie has a point. I wonder if the gauge works. I will watch gauge next time heat turns on and see if needle moves.
    What if I break it when removing and create a leak? The pipe leading to the gauge is warm.
    Also, how do I know what size thread the connector pipe is ?
    https://www.supplyhouse.com/sh/control/search/~SEARCH_STRING=steam%20gauge
  • PEvans
    PEvans Member Posts: 143
    @delcrossv is right, you need a low pressure gauge as well, to tell what is going on. Also these low-pressure gauges don't like off-scale pressures, and at least the ones I have found are expensive.
  • CoachBoilermaker
    Is it possible to explain what parts I'd need to add a 0-3 psi gauge?
    Fork from the line going to square dial in my pics above?
  • CoachBoilermaker
    I have a very non-standard boiler so I assume I can't look up a video of how to add a 0-3 gauge
  • delcrossv
    Pigtail to tee to a couple of nipples to ells to a couple of nipples to the units (add couplings as necessary).
    C'mon look and see how it should go together. Visualize. Draw a picture.
  • CoachBoilermaker
    OK, I get what you mean by a fork into 2 pipes facing frontwards.
    Pigtail would replace square gauge in front? Extending that long straight pipe a half a foot even furthur would be getting in the way of the door closing. And would look weird as hell. And risk getting broken off?
    Size is 1/4" N.P.T. ?
    I can't find a 0-3 gauge
    https://www.supplyhouse.com/Weil-McLain-510-218-045-Pressure-Gauge
  • PEvans
    The ways to do it are unlimited. Mine is a T off the main relief. My 0-3 psi gauge is a Wika purchased from wika.com.
    I think you need to retain a 0-30 psi gauge. I have a square 0-30 psi gauge on the front of the boiler that I did not mess with.
    (Yes, I know that is the wrong Pressuretrol. Not sure where it came from but It is replaced with a Vaporstat.)
    Mad Dog_2delcrossv
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,388
    If they are too hard to get out, I just add new ones elsewhere. Mad Dog
  • PEvans
    Some of you have these beautiful headers installed in a tap on the front of the boiler with low-pressure gauge, Vaporstat, and safety Pressuretrol all where you can see them, individual pigtails for each, a valve protecting the 0-3 psi gauge, and couplings everywhere for easy maintenance. That is probably the "right" way if there is one.
    109A_5 Member Posts: 3,432
    Hello CoachBoilermaker,
    Maybe that long copper pipe from the boiler to the gauge is plugged up and the gauge is actually fine.
  • CoachBoilermaker
    If I take off the square gauge, will water shoot out of the pipe?
    How do I safely remove gauge to inspect a clog in the straight pipe?
    " If I take off the square gauge, will water shoot out of the pipe? " If the pipe is above the water line probably not.
    " How do I safely remove gauge to inspect a clog in the straight pipe? " Wait for the boiler to cool down, where eye / face protection, use the correct tools.
