Steam Heater - Pipes and Heater is rust on new Boiler
We installed new Steam boiler after previous boiler went bad two years ago and now I am seeing pipe and boiler itself is rusting which we have never seen before.
This boiler has mix of piping. Some pipes are Copper and some pipes are
galvanized.
Please see attached picture with actual problem in pipes.
Could this issue due to flux used for soldering nearby pipes for steam heater which was installed two years ago ? Please advise me what to do so this type of issue never occur.
Thanks in Advance.
That pipe is leaking, or has been leaking for some time in the past. The pipe needs to be replaced and sealed up properly when replaced so it doesn't leak going forward.
Copper? Galvanized? Neither one is suitable for steam. And they don't play well together. Steam is piped in threaded black iron. Period. Nothing else.
Is the piping arrangement even close to what the manufacturer of the boiler called for?
please post some pictures from a little further away, showing all the piping at the top of the boiler.
Front, left side, right side
That boiler sure doesn't look 2 years old!
Someone did not tighten that pipe into the boiler with proper pipe sealant. Then no one noticed it for some time. then Steam and hot water leaked out during that time. When water and metal get together they like to play that Rust Game thing, You know. Technically it is called oxidation. You can clean that stuff up with with a wire brush and perhaps some matching paint. But you should really think about fixing the leak first.
And as far as pictyres of heaters are concerned, you should think about what @pecmsg said above. Can you tell me anything about what is wrong with this car by these two pictures? Make? Model? How much tire pressure is recommended?
I can tell you it is painted white! and the transmission had overdrive But what spark plug do I need?
I have both. Near pipes are copper and far pipes are galvanized. It is Slant Fin Steam heater. One of the photo does have leak which I came to know yesterday so first thing, I will get it fixed but white stuff on boiler pipe has puzzled me am I having such problem ? I have never seen anything like happening to any of my steam boiler happening. I own quite a few rental with steam boilers.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
