Radiator Union Alignment
I've just gone through the process of installing new TRVs on three of my radiators. I'm double checking everything and I was curious about the alignment of this one union. I'm not entirely sure if I'm just being nitpicky or if I should go back and redo this radiator alignment. It looks like it's slightly crooked. On this radiator, the valve didn't perfectly line up, so I had to shift the radiator around a little. Would this be considered a crooked union and should I just redo the alignment? I'm a noobie at this, so it's hard for me to judge if this is crooked or good enough.
Thanks
Yea, everything was aligned before I tightened the nut. I don't believe it's cross threaded either. I didn't think it mattered whether the straight threads were taped or not. I was just using the tape as a lubricant. Is it a big no-no or against code to tape threads? I just figured it would help tighten the nut and prevent it from seizing in the future.
A little never seize on the face and the back of the nut is all that's needed. Tape or dope on the threads of a union says you don't know what you're doing.
Not a code issue, but more of a why do it issue.
If the union doesn't leak, you're good.
And you don't need lubricant to "help tighten the nut". A union nut on a low pressure system like a residential radiator should be on hand tight, and then no more than a quarter to half a turn beyond that. Never more than that. It it leaks, tightening the nut isn't going to help — you will need to realign the union (no angular or lateral displacement at all!) and then thread the nut on to keep it that way.
a little dope on the threads can keep it from seizing 50 years from now when someone tries to take it apart.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
