Roth Tank Cracked fittings on top
DarrylWM
DarrylWM Member Posts: 4
Hello, we had a Roth Tank installed 3 years ago and when I went to add some home heating oil I notice 2 of the rings that secure the liner to the metal are cracked. The filler side actually looks slanted and the rubber seal sits higher on one side. I took them off to clean and inspect. Does this happen often or does anyone know what would cause it on these 2 specifically? The Vent and the Fuel gauge side are fine. Is this something that I should replace?
20241027_141237.jpg 20241027_141043.jpg 20241027_140418.jpg 20241027_140412.jpg
    pecmsg Member Posts: 6,769
    edited October 2024
    so get a new fitting
  • DarrylWM
    edited October 2024
    Was more wondering what would cause the fill tube side rubber seal pop out while the otger side was still flush with steel tank.
    EdTheHeaterMan Member Posts: 11,558
    My guess is the inner plastic tank has expanded or contracted in reference to the metal top section. Call Roth with your findings and see what they have to say
    CLambHVACNUT
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    How is tank vented? I see fill & heater, that leaves two tappings for fuel supply, gauge and vent?
  • BDR529
    BDR529 Member Posts: 372
    Found three tanks last week with the same problem.
    The large nuts are my concren now
    Greening
  • DarrylWM
    edited October 2024
    I just noticed the fuel gauge side has the same lean in towards the middle of the tank.
  • DarrylWM
    This was the reply I got from Roth. For anyone else that comes across this.
    "The tilt you are seeing in the molded port connection is partly due to the cracked bulkhead nut on the adjacent port letting the inner tank top settle slightly and partly an optical illusion caused by the upward spiral of the threads molded into the port.  The slight rise in the gasket under the metal tank top accentuates the appearance of the tilt and also is likely a result of the inner tank shifting during shipping.  Most of the gasket is still under the metal top providing the seal between the top and inner tank"
  • Michael511
    Michael511 Member Posts: 1
    Where do I get the Crack fitting I have the same problem
    Jamie Hall Member Posts: 26,816
    "most of the gasket is still under the metal top…". Um. Really, folks? If I put together a flange (or a cylinder head!) and tell you that well, most of the gasket is still under it, I don't think you'd be happy.
  • techforlife
    techforlife Member Posts: 127
    Overtightening will crack them. Roth has a spec. and a special tool for that.
