Need advice on demoing an old cast iron boiler
It's too big to get out of the basement in one piece. I think it's 8 sections. Maybe a chisel bit on a hammer drill to get the sections apart? The space is too small to swing a sledge hammer. Any better ideas?
Thanks
First of all, is there asbestos insulation on the boiler. If it was installed before 1950 that is a good possibility. A picture would help
If it is a newer model (1960s or newer) then there are most likely some kind of tie rods holding it together. Cut the tie rods with a sawsall or grinder. then use the chisel to separate each section.
But you need to get the asbestos removed before you start any work that may let asbestos fly into the air.
Some steel wedges used to split firewood, or a cold chisel will work. You can cut the tie rods and take them out and replace them with a new threaded rod with nuts on the inside and use the nuts to push the sections apart.
If the sections are too heavy to remove cut them with an angle grinder with a cutting disk (just cut part way through) then hit it with a sledge hammer and it will come apart where the cut is.
Safety glasses/goggles and gloves are a must.
my sections were too heavy after separating. I only had seven ft head clearance. A sledgehammer( and knee pads) shattered them but it was a workout. Plus everything @EdTheHeaterMan and @EBEBRATT-Ed said. I think , in hindsight, that a large, rotary hammer would have helped.
And wear eye protection too. Cast iron cast fracture like shrapnel. I always use a heavy tarp over the cast I am breaking to act as a shrapnel blanket.
To learn more about this professional, click here to visit their ad in Find A Contractor.2 -
A hepa respirator probably isn't a bad idea either for soot and asbestos you may have missed and various other materials you might stir up.
If there is asbestos you're probably better off finding someone with the ability to remove it in a single piece.
The boiler needs to be cold . Cut the pinch rods and wedge the sections apart. This would be the easier way..
They break up easy if you swing a 17# hammer .. Smaller ones just bounce off ….
I was in the same boat and ended up using junk removal in Seattle WA, which took care of everything without me having to drag stuff to the curb. They handled the heavy lifting, gave me a quick quote based on how much junk I had, and even showed up the same day. It made clearing out my place way less of a headache.
-1
- 120 Geothermal
