Best Wearable Carbon Monoxide Detector
I am looking for suggestions for the best wearable carbon monoxide detector to add to our technicians PPE equipment. I am looking for something rugged, easy to clip on and reliable. Right now everyone has a handheld instrument. The hope is that by finding something small and simple, the techs will clip it on everyday to make protecting themselves easier. Any suggestions would be greatly appreciated!
  • SuperTech
    SuperTech Member Posts: 2,637
    I believe the one I use is the Sensorcon Inspector. It is small, clips on and seems to be pretty accurate when tested against my Testo 300LL combustion analyzer in situations where I have come across measurable levels of CO indoors. The only downside is it's supposed to only have a two year lifespan and no replaceable sensors or anything like that are available for it.
    GGrossmichael_4
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    We also use the Sensorcon Inspector…We purchased the Calibation kit so that we can calibrate our detectors Inhouse vs sending it out .
  • Sethvel1
    Sethvel1 Member Posts: 6
    That's the one I've been seeing as well. I'll check out the calibration kit too.
    Thanks guys!
  • leonz
    leonz Member Posts: 1,761
    There is nothing small and simple for poisonous gas detection. If you really want the best of the best carbon monoxide/multiple poison gas detectors you want the Drager or MSA (Mine Safety Appliances) poisonous gas detectors as they are very rugged units.
  • SlamDunk
    SlamDunk Member Posts: 1,791
    does the sensorcon let you know if it isnt calibrated anymore?
  • Sethvel1
    I don't see that it does show if calibration is required. The calibration process looks simple though. Between these detectors, the handheld CO detecrors the techs have and their analyzers which show ambient CO, I would think they would notice if one of them was showing different than the others.
    I like the industrial model, it has an adjustable alarm down to 5 ppm. Any reading of CO should be alerted as soon as possible in my opinion. I don't understand the 35 ppm on most CO detectors in homes. I'm sure there is a concern for false alarms but if I had 30 ppm in my house, I would want to know about it.
  • ratio
    ratio Member Posts: 4,176
    It does say something when it's time for a calibration.
    I liked mine, but the audiable alarm isn't all that loud, or wasn't when I carried one (several years back). The one time I had it alert, it took a few passes walking in front of the source before I figured out what the beeping sound was.
  • Cyclops2
    Cyclops2 Member Posts: 2
    I had 1 CO home monitor in the full basement 3 feet above the floor.
    I am testing a portable Generac generator 50' from the house. Wife phones me she hears a beeping in the basement. I find the CO warning full alert.
    What is causing the CO alarm ? Right Hot day. Garage doors open. Basement to garage door CLOSED !!
    But the wind direction changed and speed was now up. Shut off generator.
    Open basement windows with a 24" fan in it and pressurized the basement and garage for about 6 hours. I am adding several more CO units 12" above the floors everywhere. I have never worried much with a TOTAL ELECTRIC house. Safest Right ? 😉
