What brand of radiator air vent do you suggest/avoid ?
Here are two that I've heard mentioned:
925005-00 Angle VARI-Valve (Heat Timer)
Vent-Rite #1 VR1 VR-1 Adjustable Steam Radiator Vent 1/8″ Male 3 PSI
«1
    ethicalpaul Posts: 9,100
    I hate Vari-Valve
    I've never used Vent-Rite but some people seem to like them OK.
    I use Maid O Mist and sometimes Gorton
    Some people like Hoffman
    Just never buy any vent at a big box store. Buy them at supplyhouse.com is my recommendation
    delcrossvkcoppexqheatSteamNow
  • STEAM DOCTOR
    STEAM DOCTOR Posts: 2,682
    Wouldn't use VV if I got it for free.
    ethicalpaulexqheat
  • clammy
    clammy Posts: 3,262
    edited October 2024
    On the cheap maid of mist ,bear in mind the quality has gone down from what i ve seen do not get from big box . Personally i use gortons yeah u may end up w a bad one but over all the better vent and if going adjustable possible hoffmann 1A
    peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • delcrossv
    delcrossv Posts: 2,204
    I've had better luck with Maid-o-mist than Gorton. YMMV
    ethicalpaulexqheat
  • RTW
    RTW Posts: 285
    I concur with comments to avoid Big Box Stores that won't miss your business. Do, buy from your local Plumbing Supply store if available in town and keep these knowledgeable small businesses in business that provide quality advice and products
    Regards,
    RTW
    dabrakemanA1000exqheat
  • dabrakeman
    dabrakeman Posts: 1,039
    Keep your pressure low enough and you won't have much issue with any of them.
    I use MoM, Hoffman 1a and Ventrite 1and I even have a box store vent on one radiator. My system operates now such that radiator with the box store vent never 100% fills so pretty easy duty for any vent.
  • Mad Dog_2
    Mad Dog_2 Posts: 8,760
    I will keep it positive. Gorton & Hoffmans ONLY. Mad Dog
    Dave in QCA
  • For fully adjustable vents we use Ventrite #1 almost exclusively. On a budget, we use Maid o Mist #4. #5, and In rare instance #6 (huge church size radiators and really screwed up condo systems) with removable orifices. We will use Gorton, #4, #5, #6 for people that are looking for higher quality fixed venting rates ( like in rentals) People tend to remove the orifice on the Maid o mists. Maid o Mist also makes fixed orifice type vents too.
    We like the ventrite because even when set for the highest setting, they are still a much slower vent than others…so a system is not thrown out of balance by excessive radiator venting. The Hofmann adjustable are not very repeatable….2 different vents set for the same number will vent at very different rates. …so we stopped using those many years ago. Anything that can vent real fast like the Maid o mist or Gorton C or Ds, and the Heat Timer varivalves (equal to 16 conventional vents) will tend to cause the system to go out of balance and/ or the radiator to spit.
    We also recommend people stay away from Big box store vents….we have seen several case (and others here have reported) seeing them split open. We had one condo building run into several thousand dollars of emergency repair calls for the boiler and then a unit owner came home from a vacation to find about 1/3 of thier unit totally destroyed by steam and water damage due to the vent splitting open.
    bburdA1000hot_rodRobert_H
  • THANKS for the advice.
    No bigbox. I like to use local biz for stuff like this, where shop can also offer advice/ local contacts.
    VariValve bad.
    Stick with Gorton, Hoffman, or VentRite
  • Are vents all the same thread size?
    Or do I have to remove first and bring to supply shop ?
    For vents without a nut at base, you just grab it and twist to remove?
  • delcrossv
    All the same size for radiator vents.
  • @CoachBoilermaker Unless you have an oddball out of left field, they are all 1/8" NPT. And yes, just grab and twist! lefty loosey, righty tighty!
    Gorton has a good diagram of which ones to use and where…. Gorton's Website
    STEAM DOCTOR
  • Dan_NJ
    Dan_NJ Posts: 268
    I used to keep a 1/8" NPT tap on hand and clean out the threads a bit any time i was changing a vent.
    exqheatDouble D
  • CoachBoilermaker
    CoachBoilermaker Posts: 487
    edited October 2024
    Missing something basic.
    The 1/8" tap is only used to clean the threads, right?
    In the video, he uses an 11/32" drill bit. That is much larger than 1/8 (or 4/32). In fact, that is 3x larger !!
    If you drill out the hole, it's now bigger than the original 1/8" and the vent will be too small for the enlarged hole?
    https://www.amazon.com/1-8-npt-tap/s?k=1%2F8+npt+tap
    exqheat
    It comes with a drill in case there is no hole where you want there to be one
  • Dan_NJ
    Dan_NJ Posts: 268
    Right, I never tapped any new, just cleaning out 90+ years of crust from existing before trying to put something new in there.
  • dabrakeman
    1/8" NBT pipe has an OD pf .405" (~13/32) that is why the associated drill for tapping is 11/32".
  • The correct tap is 1/8" 27 NPT?
  • CoachBoilermaker
    edited October 2024
  • Just like Mad Dog, I will keep it positive. Gorton & Hoffmans ONLY.
    Mad Dog_2Dave in QCA
  • Big Ed_4
    Big Ed_4 Posts: 3,590
    You pay for what you get …
  • I picked up a Hoffman 1A and am skeptical of the design. There is so much slop in the spinning cap that it can easily block the hole, or leave it wide open. It does not feel accurate at all. I am thinking of returning it. What am I missing? Just make sure cap is fully seated before tightening cap nut? Seems so easy to seat it crooked.
    delcrossv
  • @ethicalpaul @STEAM DOCTOR Why do you hate Vari-Valve brand?
    it’s too fast, hard to adjust and spits if I recall correctly
    bburddelcrossvSTEAM DOCTOR
  • I bought a VariValve at the local supply house to be polite and buy something.
    I noticed it does not close when you blow into it when upside down.
    Is this a different design? Always open, or only closes when steam enters?
  • delcrossv
    Yes, and they're way too fast for normal use.
  • delcrossv
    edited October 2024
    The "new" design 1A's are a pain to adjust. IIRC, they're all pulled off the systems I service in favor of fixed orifice vents
  • Can you explain this? The VariValves are too fast? What effect does that have?
  • STEAM DOCTOR
    edited October 2024
    And they fail way too quickly.
    ethicalpauldelcrossv
  • Anyone need my bucket of failed Heat-timer Vari-Vents?
  • Fail by leaking ?
  • Long Beach Ed
    Long Beach Ed Posts: 1,851
    edited October 2024
    No, the Heat-timers fail closed when the bellows deforms and dismounts from the cap, fouling the orifice it controls. About 25% of several hundred did this in the 18 months. A nice loss for us.
    A well-made valve with a flawed design.
  • Long Beach Ed
    edited October 2024
    We loved them at first for our properly piped jobs with dry steam. Then the calls began coming. Removed them from probably 40 jobs, again and again. Eventually we'll probably revisit every job. Call backs every month.
    When they work they are silent, very fast venting and slow closing, which use some water. Many fail and remain closed.
    Opened some and found the problem. Shared an engineers' report with the manufacturer. We really wanted them to work reliably. They're little beauties — with a flaw.
  • Any update on what you guys like these days?
  • patrykrebisz
    patrykrebisz Posts: 175
    edited January 26
    here is a comprehensive video i've made comparing most popular valves:
  • BobC
    BobC Posts: 5,582
    These are cjinese lmpckoffs os a once viable ventgave a history not really being adjustable and having a bad reliability reputation They used to be dirt cheap but I see they are now asking a premium, pride - I recommend staying away from them.
    I've used maid o mist and had good luck with them (no failures in a decade or so). Recently there has been talk of reliability problems of both maid o mist and gorton; the gprton's cost a lot more for no apparent reason - make sure you buy either from someone who accepts returns. Heat timer Varivent are getting a bad rep on reliability, zero quality control.
    Hoffman makes reliable vents but some have problems with them on systems with long tadiator runouit pipes.
    3PSI gauge
