Regulator and backflow preventer in the feed line
I have an aqua balance spoiler system and
I ran into an article but discusses how the backflow preventer should be before the pressure regulated in order for the system to work right, I have enclosed a copy of that article along with a photo of my system, any thoughts on this?
Okay now that we got that code violation out of the way what about placement of the regulator in relation to the backflow preventer?
Backflow preventer first-regulator second-boiler third. Do I have that right??? hmmm
From what little I can see in that photo, you need to get a professional to review that work. Especially the relief valve configuration. Also, there is no
safe dischargeorsafety tubeattached to your back-flow preventerOther than that, I have no idea what that arrow is pointing to. But I never installed or serviced that brand of equipment.
Edit: what can happen if your relief valve does not work because it is installed backwards
https://makeagif.com/gif/mythbusters-water-heater-explosion-yInJnq
From the photo I can't tell if the relief valve is connected properly to the pressure vessel. Is that a tapping on the right from the boiler that is painted white or is the white device on the left where the elbow is connected to a pipe nipple, a tank that is painted white?
Hi, About the T&P, if it is the type that really has the temp probe, it cannot really sense the stored hot water temperature as it's out in a pipe. So, whether you go with the Mythbuster video or the "Explosion Danger Lurks" video from 1942, the result is the same. It's unsafe as installed.
Yours, Larry
It also looks to be backwards but I can't quite tell from that picture. The male tapping in line with the stem pf the pressure relief valve should be in the pressure vessel.
- 116 Geothermal
- 169 Indoor-Air Quality
