Regulator and backflow preventer in the feed line
I have an aqua balance spoiler system and
I ran into an article but discusses how the backflow preventer should be before the pressure regulated in order for the system to work right, I have enclosed a copy of that article along with a photo of my system, any thoughts on this?
  • Ironman
    Ironman Member Posts: 7,918
    By code, the vent outlet of the BFP has to point downward when it’s installed in the horizontal position.
    Bob Boan
    hot_rod Member Posts: 27,709
    and a discharge pipe to the floor or indirect waste
  • photokynetics
    photokynetics Member Posts: 73
    Okay now that we got that code violation out of the way what about placement of the regulator in relation to the backflow preventer?
  • HomerJSmith
    HomerJSmith Member Posts: 2,793
    Backflow preventer first-regulator second-boiler third. Do I have that right??? hmmm
    EdTheHeaterMan Member Posts: 12,451
    edited September 2024
    From what little I can see in that photo, you need to get a professional to review that work. Especially the relief valve configuration. Also, there is no safe discharge or safety tube attached to your back-flow preventer
    Other than that, I have no idea what that arrow is pointing to. But I never installed or serviced that brand of equipment.
    Edit: what can happen if your relief valve does not work because it is installed backwards
    https://makeagif.com/gif/mythbusters-water-heater-explosion-yInJnq
    From the photo I can't tell if the relief valve is connected properly to the pressure vessel. Is that a tapping on the right from the boiler that is painted white or is the white device on the left where the elbow is connected to a pipe nipple, a tank that is painted white?
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,144
    Hi, About the T&P, if it is the type that really has the temp probe, it cannot really sense the stored hot water temperature as it's out in a pipe. So, whether you go with the Mythbuster video or the "Explosion Danger Lurks" video from 1942, the result is the same. It's unsafe as installed.
    Yours, Larry
    mattmia2 Member Posts: 17,222
    It also looks to be backwards but I can't quite tell from that picture. The male tapping in line with the stem pf the pressure relief valve should be in the pressure vessel.
