Can Pex be fished through copper ?
May have a radiant floor leak, was wondering if there's any hope of fishing pex through the old tubing or if I'm doomed to chipping up the floor or abandoning the radiant and putting in fin tube.
PEX has the same size as copper, so you'd have to go down a size, which may not support the flow you need. A piece of 1/2" PEX will fit inside of 3/4" copper although I don't think you could get it to go around an elbow. You can try for yourself. The bigger problem I see is the PEX won't make good contact with the copper so you won't have good heat transfer.
I think you have to abandon the copper.
3 -
Consider raising the floor and go right over the old slab with pex & a mud job. Some new saddles, cut down your doors...Mad Dog 🐕
Nah, it's next to a zone that's still working.
I'd probably run fin tube along the exterior wall and abandon the radiant 😞
ditto. Plaster & painting may be involved but mounting panels at ceiling height works even better. And if it's only one room electric is easier.
Ceiling radiant, radiant walls, panel radiators. are other low temperature options.
What tuype of boiler? Unless it is a mod con, go with high temperature emitters that take less wall space. High output baseboard maybe?
Old school hot water. Still has the B&G 100 circulators.
I'm liking the Runtal panel idea. Can I run those at high (180-190 degree) temp?
Seems so. And they're available with both connections at one end! 😃
what makes you think whatever caused the failure isn’t happening in the working section?
It's in a slab so that won't work. Needs to be some kind of baseboard. But thanks for the suggestion.
It probably is, but that section was put in 30 years later. If it ain't broke….
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
