My garden is unusable because of the smell
Hoping someone can give me some guidance. My attached neighbours oil tank is right next to our boundary wall and has a vent pointing over the fence. Every time there's the littlest bit of sunshine my garden and house stinks. I have to keep the back door and windows closed to try and keep it out but when you open the door to use the garden the smell of the oil tanks hits you right in the face, to the point you can taste it for hours afterwards. My eyes are steaming writing this and the odour can be trigger for my chronic migraines.
Is there anything I can do or do I have to just put up with it. We're not on speaking terms as it is (never have been, not done anything, when we moved in and said hi it was responded with "we don't talk to neighbours or trust anyone"). They are council renters, we own privately. Can I just message the council? Everyone else in the street are gas or electric, these neighbours insist on being "off grid" and pay oil company cash for the oil.
I’d reach out to code enforcement to see what set back requirement exist for fuel tanks.
You mentioned “council renter”; are you located in the UK? If so I’d definitely contact the council who owned the property or the body responsible for environmental code enforcement.Let us know how it works out.
2 -
Assuming you are in the UK, this site may be helpful.
Minimum setback appears to be 780 mm from boundary line (about 31”). This would also apply to any venting pipes.Edit: the tank shown in the image at top of page appears to be right on property line. 🙃
Hard to believe an oil tank could result in such an obnoxious smell.
But yes call code enforcement that is the first step.
Does this smell continue for 24 hours a day 7 days a week?
Sounds more like a leak that has soaked in.Call your Local HealthDept too. This is an environmental issue..Mad Dog
3 -
I'd be concerned there is an active oil leak that has leached in to the soil. You shouldn't be getting such odors front Fuel oil tank vent..On fill up ? OK, but once it's settled all the vent is doing is keeping the tank from going in to a vacuum..Mad Dog 🐕
2 -
I have worked on several leaking underground tank projects.
You could not smell anything until the digging started. Then the fumes would just about knock you out.
Diesel and gas both when in the dirt really cook up some smells.
Do you have a basement or cellar, do you smell anything under your house? If you dig in the garden close to the boundary line do you smell oil in the soil?
As stated above, this could be an "oil spill" environmental disaster.
I wonder if the UK uses some different grade of oil that has more volatile components.
Probably the other way around… i.e Lower sulphur contend in Europe.
if this is the uk there a few things to consider. Most council rented properties have been farmed out to housing associations so the local council/local authority no longer owns and manage the property. Whoever is responsble for the maintenance of the heating system will person who needs to sort this out. The maintainer of the heating system will inspect the storage tank and comment on conditon and report any leaks after every visit.
Modern/replacement oil tanks must be bunded (double skinned) and there are more strict rules on where they can be located. The tank being described could be old and located under much older regulations.
The body really responsible is the national Environment Agency but I don't know if they delegate responsibility to local authorities for domestic heating oil.
Of you believe there is an oil leak (the concensous here seems this is likely) contact the Environment Agency and ask for advice. On way or another this should get things moving.
John
I wonder what the actual smell is. Could it be oil tank algae? That would be a very bad smell and she does not say that it smells like a diesel truck stop.
the sun heats the tank, causing oil fume air to be pushed out, it isn’t much of a mystery. Oil smells bad <shrug>
or like Matt said, it’s leaking or they spill it when they fill it.NJ Steam Homeowner.
If it is just VOC off gassing from sun heating, a carbon filter might be a good mitigation. Protecting a ready made one from the weather and how long it lasts is a question. water is the enemy of charcoal when filtering gases. They aren't that expensive and one for that application isn't hard to make. Filling a vertical 4'-4" plastic pipe with activated coconut charcoal pellets with screen to keep them in at the bottom. Keep the bottom off the ground and use a water tight connection to the tank vent pipe at the top. That would be my college try. That is, if I knew for a fact the smell comes from JUST the vent pipe termination.
