15 psi high pressure steam?
What is the deciding factor of 15psi being the number that separates high pressure and low pressure steam? My teacher gave us a table of properties of saturated steam and told us the answer would be found on the sheet. Thinking it has something to do with the volume or 15psi being over 14.7 (atmospheric) pressure
15 psi gauge
O. Then the fact that the number 15 in regard to the dividing line pressure happens to be similar to the absolute presssure of the atmosphere is quite irrelevant.
What is relevant is that there needs to be a definite line for the various code requirements for high pressure steam — which is quite lethal in an enclosed space, and which can do sever harm from even a relatively small leak — and low pressure steam which, while it can still blow up under some conditions, and do a lot of damage isn't quite so hazardous.
Why 15 psig was chosen, however, I honestly don't know. Hopefully someone here can!
Do you know the history of how or why they came up with 15 PSIG?
Talking through my nose here. Factor of safety test low pressure boiler at twice 15 psia. Well if it passes then 15 psig is probably okay? I've seen "atmospheric boilers" operate at over 10 psig indefinitely. Very often you see heating boilers operate at such high pressures to "blow the condensate through traps". Intelligent experienced folks can have misconceptions.
HP steam needs to be worked on like High Voltage wire...Like your life depends on it. Mad Dog
HP steam is used for one of two things . Distribution or temperature.
Distribution like in hospitals or for district steam and industrial plant where the steam lines are very long you can use much smaller pipe with HP steam
Temperature some processes need more heat than 15 psi steam can provide. Kitchens, sterilizing, brewing, drying etc.
It seems in 1900 in Belgium, the "effective pressure" (gauge pressure) for domestic heating was limited to "1/4 d'atmosphère " which was 3.673…. psig.
"low pressure" is actually 1/2 bar or 7,251887 psig. The testing pressure is 1.5 bar.
- 120 Geothermal
