EPA test?
GW
Member Posts: 5,183
I have somebody interested in the trades, she would like to begin working with us this spring. While she’s finishing up her current job she’s trying to gain whatever book-smarts she can. Are there any good outlets to do an online EPA test? I did mine over 20 years ago, in a classroom, so I don’t know what’s good these days.
Thanks
3 -
@GW
Actually, the one that @ChrisJ posted is probably better.
Sid Harvey, Bell Simons, R E Michel, Johnstone and United Refrig. all in Springfield are listed.
or
You might contact PHCC of MA @ 1-781-843-3800 or their web site www.phccma.org. They just had a class in West Marlborough on 3/1. $225 for members and $300 for non members. I think they do a class and take the test the same day.
I am sure they will be having more classes.
Got mine in 92' or 93' when they first came out.
Used to be easy back in the day all you needed on your truck was 502, 12 and 22.
They call this EPA 608 I guess that is wat you need. Type 1, 2 or 3
The local rumor mill is that the plumbers and heating guys who have never done any refrigeration work are looking to get into the heat pump craze because of the new GREEN heat pumps and also some towns in MA are not allowing gas or oil.
So at least around here there is more activity about the EPA 6081 -
@GW, our friends at The ESCO Institute have the EPA test available online here. They also have a training course here. @Eugene_Silberstein is their National Programs Director.
President
HeatingHelp.com2 -
Kudos to the guys who are looking to add heat pumps on their shingle now. We all see the trends and where the HVAC profession is heading. The fossil fuel market is shrinking. So you can sit and do nothing as your phone traffic dies, or change with the times now.
Hiring qualified men is where it starts. You are only as good as your field guys. The problem is, there are not many techs to hire. At my place of employment, we do training from within. I teach a class 2x a month. This company does a ton of plumbing too. Some of those guys want to cross over to more HVAC and boiler heating. It works for us. It accelerates that learning process a bit where we can make money on him. Challenging times.
Steve0 -
Ed yes it’s gravy work until something goes wrong. “Yes we install heat pump (but don’t call us for service)”——seems to be a thing. Probably nothing newEBEBRATT-Ed said:The local rumor mill is that the plumbers and heating guys who have never done any refrigeration work are looking to get into the heat pump craze1 -
Yes that’s tru for sure. Some guys can't get into sophisticated control strategies (wifi set up, pc laptop connected diagnostics, “system sizer” programs, manual J that are somewhat close to reality, complicated setting changes with commercial/VRF systems etc etc. I think it’s always been true that there was a little separation between the worker bees in the field and the owner/manager that did the heavy thinking/ layout. But now it’s been amped up quite a bit. if the owner/manager can’t do this stuff, there’s going to be spaghetti flying all over the place, seeing what sticks. A mistake can be very costly, especially here in Massachusetts, where things are hyper focused on rebate money,Mustangman said: Hiring qualified men is where it starts. You are only as good as your field guys.1 -
Super I pointed my lurker person to this page. Carly you tuning in ?😀Erin Holohan Haskell said:@GW, our friends at The ESCO Institute have the EPA test available online here. They also have a training course here. @Eugene_Silberstein is their National Programs Director.3 -
Ed yes it’s gravy work until something goes wrong. “Yes we install heat pump (but don’t call us for service)”——seems to be a thing. Probably nothing newGW said:EBEBRATT-Ed said:The local rumor mill is that the plumbers and heating guys who have never done any refrigeration work are looking to get into the heat pump craze
the thing this misses is those things went wrong because they didn't understand what they were doing.0 -
No, systems have glitches that were installed perfectly well.
but yes, a bad install, that of course is a different conversation0 -
passing the refrigerant certification exams isn't going to teach you how to install refrigeration systems. it is necessary to handle refrigerant but there is a whole bachelor's degree worth of stuff you need to know to do it properly.0
I'm pretty sure @GW is more than aware of what's required.mattmia2 said:passing the refrigerant certification exams isn't going to teach you how to install refrigeration systems. it is necessary to handle refrigerant but there is a whole bachelor's degree worth of stuff you need to know to do it properly.
Thanks Chris I sure do try. The general topic was regarding a newb in the trades0
I respectfully suggest stop only thinking about hiring men and double your potential work poolMustangman said:Hiring qualified men is where it starts. You are only as good as your field guys. The problem is, there are not many techs to hire.
Chris OK cool well it seemed like you were sticking up for me nevertheless, thanks0
I just found my very first test results from Ferris State University. in a box of old documents. I only passed the core and type I the first time out, and my certification number was my social security number. Now that one is OLD!
@EdTheHeaterMan
Mine was Ferris State too.
It is so old I can hardly read it. Can't remember when they first came out? 92? 93? mine is out in my truck. Not going out there to look.
Passed all of them. Probably couldn't pass any of them now.
Ferris state must have had quite the deal.0
- 123 Chimneys & Flues
