Water in sight glass
amcauley
Member Posts: 4
in Gas Heating
Would you be able to advise why there is continuous water in steam boiler? The main water line to boiler has been turned off, yet each day I have to drain the boiler. Usually about 4 buckets before the water returns to normal level in sight glass. I have turned the boiler off and water continues to fill in.
Water doesn't self-generate so there is some connection from fresh water to your boiler.
Just an update I have a gas boiler.0
Or an indirect water heater.Jamie Hall said:Is there a tankless domestic hot water coil on the boiler? If so, there's your problem. It's leaking...
Well that puts paid to the slow return theory. The boiler is turned off. The radiators in question are turned off. Any trapped condensate they had has come back long ago... or isn't coming back at all.amcauley said:Would you be able to advise why there is continuous water in steam boiler? The main water line to boiler has been turned off, yet each day I have to drain the boiler. Usually about 4 buckets before the water returns to normal level in sight glass. I have turned the boiler off and water continues to fill in.
I wonder if @amcauley is still having this problem?
Is there a chance that a feed valve is passing? even if the valve is completely closed but some water ls still passing, like a dripping faucet might be completely closed but a drip still happens. All you would need to fix this is a new valve that does not pass a little drop of water even when completely closed.
If you are a decent DIY kind of person, this will be no problem for you. If you do not have the skill set to replace a leaking valve, then a plumber would be in order.Edward Young Retired
