Why is two of these valves closed and the other open? [Solved]
Hi, Can you back up a bit, so we can see where those pipes run? Thanks.
Yours, Larry0 -
Yes, thank you for your reply. He sent me these photos. Recently bought condo and heat is working but hot water is not but when he originally tested the hot water a few months back, it worked (winter months heat was off but turned on during inspection). The three valves seem to be intake and outlet and one is off to prevent cross flow.Larry Weingarten said:Hi, Can you back up a bit, so we can see where those pipes run? Thanks.
Yours, Larry
Those valves control flow through the autofeeder which maintains the water level in the steam boiler. I see two of them open (handles parallel to the pipes) and one (handle perpendicular to the pipe) which would be correct.Br. Jamie, osb
Yes, I have him sending more photos. supposedly he stated there are two valves above the boiler one is closed and the other is open. They are right next to each other and he didn't want to touch them because they are red.Jamie Hall said:Those valves control flow through the autofeeder which maintains the water level in the steam boiler. I see two of them open (handles parallel to the pipes) and one (handle perpendicular to the pipe) which would be correct.
That boiler does not appear to be set up to heat tap water, but just to make steam for space heating. There should be a separate water heater somewhere.—
Bburd0 -
The open valves would only be closed if the auto feeder (box with wire connected) needs to be serviced. The valve that is closed would be to manually fill the boiler, in the event the auto feeder did not work. All is well, just leave them as they are. BTW, the color of the valve seldom has any relevance."If you can't explain it simply, you don't understand it well enough"
Albert Einstein4 -
While I'm waiting for the additional photos, what is that box with the red button? does the read button manually feed water? or is it a reset? Just curious, I've only seen these on another Weil system.Jamie Hall said:Those valves control flow through the autofeeder which maintains the water level in the steam boiler. I see two of them open (handles parallel to the pipes) and one (handle perpendicular to the pipe) which would be correct.
This was my initial thought but then learned there is only one water heater but it's connected to the other unit. The other units hot water and heat are working. I was there last night and could not find a hot water heater anywhere. I looked in closets, cabinets, and two crawl spaces. So I assumed that this boiler created both heat and hot water. Not even sure who to direct his call to in this matter.bburd said:That boiler does not appear to be set up to heat tap water, but just to make steam for space heating. There should be a separate water heater somewhere.
Good thinking, while I did the first two, kitchen and bathroom, I did not check behind or near the washer and dryer which is in the two level unit.bburd said:Try following the hot water pipes from under the kitchen or bathroom or near the laundry back toward the source. Somewhere there is a heater.
As an alternative, you could start at the water meter and go forward to find where the water heater is connected.—
Bburd0 -
That is the autofeeder, The red button should manually feed water when you push it... that is assuming I'm looking at the same three valves and box you are...CluelessBro said:
Mods please keep this thread open, I'm going by the residence tomorrow and will be investigating. Thank you. I will alert when it's solved.0
Jamie Hall said:
That is the autofeeder, The red button should manually feed water when you push it... that is assuming I'm looking at the same three valves and box you are...Those valves control flow through the autofeeder which maintains the water level in the steam boiler. I see two of them open (handles parallel to the pipes) and one (handle perpendicular to the pipe) which would be correct.
I used everyone's suggestions and knowledge and followed all the lines. One lead to another unit, where the boiler provides heat/hot water and they also have a gas water heater, which made no sense. Did some investigating, saw pilot was out, checked the gas line to see if it was secure and not compromised. Started pilot, waited 10mins and checked his water, fixed. No clue why it's so far from the source but glad it's working. My one worry is that it's so far away and there isn't much access unless someone makes contact with that tenant, which makes me believe the same family lived on every level and side.bburd said:As an alternative, you could start at the water meter and go forward to find where the water heater is connected.1 -
Just curious...are you just a friend, or an HVAC technician friend?
Friend with minimal heating knowledge, no ventilation knowledge, and 200 level AC knowledge. Everything I learned was online via YT fasttrack. Had a water heater problem myself a few years back, which is oil, was lucky I was home about 12 gallons dumped on the floor. Turned valves off immediately then hit the books. Learned fairly quickly (because the water was coming out excessively) it was a temperature and pressure valve then replaced it. Spent the Saturday night learning boiler101 and the best clues were delivered to me from this forum, especially this discussion. Water Heater to me makes sense by looking at it. The components are self explanatory, boiler I never owned personally. I studied electronics in HS, so schematics and how things work comes rather fast and now a fulltime trader after being in the hospitality industry for over two decades.ethicalpaul said:Just curious...are you just a friend, or an HVAC technician friend?
