Make it work....
Mad Dog_2
Member Posts: 7,076
Oops! Must be a plastic drain. With cast it's a straightforward fix even with poured joins. How would one do that with plastic? Cut it out with a router?EBEBRATT-Ed said:Didn't square the flange holes with the wall.
It would be great if we could assume that anytime we saw something like this it was done by an unlicensed individual.NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el4
Its ok for some one who is a right hander.
As for the lefties? Not so sure.
If you know. You know? .0 -
Looks like loose Johnny bolts and a very forgiving wax seal.0
This was done by a GC...one call does it all..PVC and Home Depot made everyone a plumber...Mad Dog 🐕4
It's probably not even bolted to the flange (floor). Of course, it could be covering up a cracked tile. Works for me.0
Mad Dog_2 said:This was done by a GC...one call does it all..PVC and Home Depot made everyone a plumber...Mad Dog 🐕
@Mad Dog_2is this a job you're quoting to fix?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment1 -
Damn Orangeburge, made everyone a plumber before it was cool.ChrisJ said:Mad Dog_2 said:This was done by a GC...one call does it all..PVC and Home Depot made everyone a plumber...Mad Dog 🐕
mine was installed by a plumber. i have a copy of the permit from 19500 -
You could drill the floor and install threaded "shields" and use hanger bolts to hold the toilet. Thread the screw end into the "shield" and use a nut on the other end to hold the toilet. "Shazam", problem fixed. Ace Hardware sells them in a set of 2 in brass. See item #43037. I am sure that any hardware store or outlet sell similar items.1
No. Matt Jr's Batchelor pad in Williamsburg Brooklyn. Believe or not, it's down good, good tile job & clean. Mad Dog 🐕1
You can also store, brooms, mops, New York Magazine & National Geographic behind that toilet! Mad Dog 🐕0
You could store 10 years worth of McMaster Carr catalogs behind that toilet.....Mad Dog_2 said:You can also store, brooms, mops, New York Magazine & National Geographic behind that toilet! Mad Dog 🐕
Or a spare TH400 / 4L80E.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment3 -
A steam radiator would be perfect back there.0 -
A steam radiator would be perfect back there.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment2 -
Butt for the left handed folks its much worse then for the righties. Look at the pic again.0
You just gotta practice the "reach around." HA ha 😂 🤣 😆 😄 Mad Dog 🐕0
If it's all the same to you I'd rather not.Mad Dog_2 said:You just gotta practice the "reach around." HA ha 😂 🤣 😆 😄 Mad Dog 🐕
I just pulled one of my vintage toilets (flushmetered) and it had four bolts into the floor - two into the flange and two long post screws into the concrete floor. The other toilet only had two at the flange - I'm assuming they are both original to the late 20's, but maybe it was replaced in one of the weird renovations that were - somewhat badly - done over the years.0
@ChicagoCooperator usually there is a date stamped in the porcelain somewhere inside/underneath. I think the 4 bolt was common through the 50's or so, first all 4 bolts in the floor just holding it over the flange and later with 2 studs in the flange.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
