Make it work....
Mad Dog_2
Mad Dog_2 Member Posts: 8,681
Precious...mad Dog 🐕
delcrossvGGrossAlan (California Radiant) Forbes
  • delcrossv
    delcrossv Member Posts: 2,204
    Installer couldn't square it up?
    Mad Dog_2
    EBEBRATT-Ed Member Posts: 20,485
    Didn't square the flange holes with the wall.
    delcrossvCLambMad Dog_2
  • delcrossv
    edited February 2024
    Oops! :D Must be a plastic drain. With cast it's a straightforward fix even with poured joins. How would one do that with plastic? Cut it out with a router?
    mattmia2 Member Posts: 17,478
    this very definitely looks like diy bathroom in a basement or basement bathroom done by people who didn't have any sort of license.
    delcrossvMad Dog_2
    ethicalpaul Member Posts: 8,933
    It would be great if we could assume that anytime we saw something like this it was done by an unlicensed individual.
    Larry WeingartenCLambMad Dog_2rick in Alaska
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,622
    Easier to watch the bathtub filling, without straining your neck
    delcrossvmattmia2
  • Intplm.
    Intplm. Member Posts: 3,083
    Its ok for some one who is a right hander.
    As for the lefties? Not so sure.
    If you know. You know? . :)
  • DJD775
    DJD775 Member Posts: 259
    Licensed or not, who in their right mind thinks that's ok???
    Mad Dog_2
    HVACNUT Member Posts: 7,526
    Looks like loose Johnny bolts and a very forgiving wax seal.
  • Mad Dog_2
    This was done by a GC...one call does it all..PVC and Home Depot made everyone a plumber...Mad Dog 🐕
    DJD775mattmia2realliveplumberIntplm.
  • HomerJSmith
    HomerJSmith Member Posts: 2,794
    It's probably not even bolted to the flange (floor). Of course, it could be covering up a cracked tile. Works for me.
  • ChrisJ
    ChrisJ Member Posts: 17,519
    edited March 2024
    Damn Orangeburge, made everyone a plumber before it was cool.  :D
    @Mad Dog_2is this a job you're quoting to fix?
    Mad Dog_2
    mine was installed by a plumber. i have a copy of the permit from 1950
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,728
    Easy to clean behind the tank.
    Retired and loving it.
    Mad Dog_2GGrossCLambLarry Weingarten
  • retiredguy
    retiredguy Member Posts: 1,100
    edited March 2024
    You could drill the floor and install threaded "shields" and use hanger bolts to hold the toilet. Thread the screw end into the "shield" and use a nut on the other end to hold the toilet. "Shazam", problem fixed. Ace Hardware sells them in a set of 2 in brass. See item #43037. I am sure that any hardware store or outlet sell similar items.
    MikeAmann
  • Mad Dog_2
    No. Matt Jr's Batchelor pad in Williamsburg Brooklyn. Believe or not, it's down good, good tile job & clean. Mad Dog 🐕
    GGross
  • Mad Dog_2
    You can also store, brooms, mops, New York Magazine & National Geographic behind that toilet!  Mad Dog 🐕
  • ChrisJ
    edited March 2024
    You could store 10 years worth of McMaster Carr catalogs behind that toilet.....
    Or a spare TH400 / 4L80E.
    GGrossMad Dog_2MikeAmann
  • KC_Jones
    KC_Jones Member Posts: 5,939
    Considering what website this is.
    A steam radiator would be perfect back there.
    2014 Weil Mclain EG-40
  • ChrisJ
    Or a 3 section boiler....
    Mad Dog_2SuperTech
  • Mad Dog_2
    A small beer 🍺 fridge
  • Intplm.
    Butt for the left handed folks its much worse then for the righties. Look at the pic again. :o
  • Mad Dog_2
    You just gotta practice the "reach around." HA ha 😂 🤣 😆 😄 Mad Dog 🐕
  • ChrisJ
    If it's all the same to you I'd rather not.
    Mad Dog_2GGross
  • ChicagoCooperator
    ChicagoCooperator Member Posts: 363
    I just pulled one of my vintage toilets (flushmetered) and it had four bolts into the floor - two into the flange and two long post screws into the concrete floor. The other toilet only had two at the flange - I'm assuming they are both original to the late 20's, but maybe it was replaced in one of the weird renovations that were - somewhat badly - done over the years.
    @ChicagoCooperator usually there is a date stamped in the porcelain somewhere inside/underneath. I think the 4 bolt was common through the 50's or so, first all 4 bolts in the floor just holding it over the flange and later with 2 studs in the flange.
  • Intplm.
    Or be ambidextrous. :D
