elbows in basement discolored?
ahearnj
Member Posts: 3
Posted the other day about testing pipes and if I should be worried about chasing leaks in horsehair plaster walls. Here’s pics of some pipes in basement, 11 radiators in total, 2story home. Straight Runs in basement look great(like replace in this century), but elbows/pipes at basement boards I see much more corrosion.
Not getting cheap replacement quotes, so no deal here, but won’t guarantee pipes either. I love the look and feel of steam but should I just abandon for baseboard, can’t afford chasing pipe leaks.
Current gas furnace has not been working for many years and already scrapped. It’s cold in NE so really need a decision soon. Anyone in RI that is on this feed?
Take your time, get the EDR of the current radiators to properly size the replacement boiler0
that white, heavier deposits, might be asbestos, (?)known to beat dead horses0
After you install the new boiler, try scraping the rust off with a wire brush. Then use some silver paint on those elbows. They will look like new.
112 years old and a little paint about 60 years ago.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
- 50 Industry Classes
