Leak in pipes
lytobi11
lytobi11 Member Posts: 2
One of the pipes that goes along the lines from my furnace is leaking. I don't know if I should turn off my furnace as it is cold outside..  should I worry or can it wait..
    hot_rod Member Posts: 27,072
    A drip or a stream? You probably have a boiler, add a pic so we can see the piping. It needs to have an operating fill valve to maintain the water in the system as it leaks.
    Sooner instead of later to get it repaired.
    If you have piping exposed to freezing conditions you don’t want to risk a freeze up. How cold is it getting outside?
  • lytobi11
    Is about 30 degrees..
    pecmsg Member Posts: 6,881
    Get someone in to repair it.
    Mad Dog_2
    Jamie Hall Member Posts: 27,004
    Keep it running. In the meantime, until you can get it fixed, there are tapes which can be used to at least moderate success to slow down the shower.
  • Intplm.
    Intplm. Member Posts: 2,906
    When you do get it fixed, make sure the upper and lower pipes are not rubbing/touching. That might be the cause of the leak.
    Larry Weingarten
