Leak in pipes
A drip or a stream? You probably have a boiler, add a pic so we can see the piping. It needs to have an operating fill valve to maintain the water in the system as it leaks.
Sooner instead of later to get it repaired.
If you have piping exposed to freezing conditions you don’t want to risk a freeze up. How cold is it getting outside?Bob "hot rod" Rohr
Living the hydronic dream0 -
Is about 30 degrees..0
Keep it running. In the meantime, until you can get it fixed, there are tapes which can be used to at least moderate success to slow down the shower.Br. Jamie, osb
- 125 Chimneys & Flues
