Steam Air vent
mmc239
Member Posts: 94
What size steam air vent should I put on a steam baseboard located right above the boiler. The baseboard bangs a lot on start up. Should I use a valve with a bigger whole to get the air out of baseboard?
Smaller hole. The vent isn't the cause of the banging. It's much more likel to be that the baseboard isn't pitched properly -- it needs a really good pitch (I'd want at least an inch, even for a short baseboard, and maybe more) to the drain, or the pipe feeding it isn't pitched properly (half an inch per foot isn't excessive).Br. Jamie, osb
I have pitched it. Shut off valve is open completely. I have tried everything. It bangs on startup, then quiets down. I have tried Varivalve, water just shoots out of them. Hoffman, some water spits out, sometimes air would not bleed out of it and radiator would be cool. Right now I have Maid o mist, it seems to be the best for not spitting water.0
It's not the vent. It's as Jamie says, there's something about your system that is putting that water there.
One or more of:
- pitch of the convector/baseboard
- pitch of the supply pipe to the convector/baseboard
- near boiler piping being all fouled up, causing surging
- water quality being poor (dirty or oily), causing surging
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 50 Industry Classes
