Black Soot Everywhere!
floors. What causes this, what can we do as renting tenants, does carbon monoxide present itself like this, what is the appropriate direction to go forward legally, please advise!!
lleebb said:
How unhealthy is it to be breathing this stuff in?
The soot is a carcinogen. Your home is a disaster (not your fault). You need to move out now!lleebb said:Our landlord will not dispatch a technician from the oil provider to our house,
The house needs to be emptied out, cleaned, and painted. Not your problem, and your landlord sounds like a moron, so I think its time for you to move on.
All your stuff needs to be cleaned as well. Take what you absolutely want and have to keep and leave the rest.
Why not? I'm sorry you are in this situation. This is going to sound harsh, and I don't mean it to.lleebb said:nor do we have any carbon monoxide detectors or smoke alarms.
You need to make some changes in your life, and you need to take ownership of things you can do to make your life better for you and your family. One of those things is to go to Walmart and buy the cheapest smoke alarm and CO alarm. Your local fire department may have some free ones, so check that out too. You will need both of these in your next home. It is your responsibility to take care of yourself and your loved ones. Yes, your landlord should have provided both of these items, but they didn't. Even if the landlord had provided these, as is their legal responsibility, how would you know they work? Get your own. You can have more than one CO and Smoke alarm. You should. You and your family are worth it.
4 -
And on your way out, turnoff the power to the oil burner. Better yet, turn it off immediately after you read this. That thing is killing you, but there is also a decent chance that it will burn you down as well.Br. Jamie, osb
Call the fire department now. Take pictures of everything. Send you landlord a picture of the kitchen. A restoration company is going to have to clean everything if possible or replace everthing. The landlord should be putting you into temporary housing at their expense. The oil company needs to see the picture of the kitchen, if they don't want to come out they are just plain nut's once they see that. But Please Call the Fire Department first. You don't want any cover up from the landlord or the oil company. The landlords insurance company is going to have to work this out with the oil company insurance, depending upon what is wrong. The fire department is your friend, they should help you.2
Imagine what your lungs will look like after one heating season!
And we Wonder why young people who never smoked have lung cancer. You likely have a cracked heat exhanger in your furnace. Soot from combustion gases are getting into your heating air instead of going up the chimney.
If you are financially strapped, go out and buy oil filled electricc heaters for each room and shut the furnace off. One month of oil will pay for the heaters.
But yeah, new living quarters would be best.0 -
I agree with the above posts. Not safe. Since the landloard will not resposnd you have every rite to protect yourself.
1. Health dept
2. Fire dept
3. call a lawyer & take pictures and follow the lawyers instructions
4. shut it off
Are you the only tenants in the building?0 -
This looks like a hot-water system, so unless the boiler is leaking it isn't "cracked". But it might be plugged with soot, or there might be a chimney problem. I agree, get out of there now. Check the laws in your state to see if you can put the rent into an escrow account until this is fixed and cleaned up.SlamDunk said:Imagine what your lungs will look like after one heating season!
But yeah, new living quarters would be best.All Steamed Up, Inc.
Consulting0 -
@Steamhead , I wondered about that but clearly the vents were blackened.0
That's a convector. The soot is drafting up through it and blackening above the outlets.SlamDunk said:@Steamhead , I wondered about that but clearly the vents were blackened.
Consulting5 -
Hi, @lleebb said there is a "propane woodstove" in the kitchen. I'm not sure just what that is. Also, the sooting is bad in the kitchen. I'd like to see pictures of this stove and how it's vented, if it is. Propane can produce just the sort of soot mentioned, and quickly. For certain, do turn off the gas supply to it until things are figured out and resolved!
Yours, Larry3 -
It could have been a 'backpuff' from the oil burner or the stove. Never seen or heard of a propane-fired woodstove. You must mean a propane fired stove that resembles a woodstove. You need to evacuate to a hotel or friend's house, wash all your clothing and selves, then begin calling authorities. I'd start with the fire marshal; If you have renter's insurance, contact the agent to file a claim. Write a letter return receipt to the property owner the house is uninhabitable and demand it be corrected, cleaned and inspected. Most codes require UL listed CO alarms but they are merely death alarms and do not protect from CO poisoning. Get a low level CO monitor. Take a few samples from hard surfaces like glass: use a cotton ball dampened with alcohol, swab until black then place in marked Ziplock bags and retain custody including noting where sample taken.0
@Bob Harper
My dad mentioned a kitchen stove his parents had in the 50s a few times that apparently was an electric stove combined with a wood stove
Apparently the wood side did heating but also could be cooked on and then it had electric elements as well. He thinks Sears made it.
So I guess a wood + lpg could exist?
EVERYTHING THAT WAS SAID ABOVE ABOUT THE HEALTH DEPARTMENT AND THE FIRE DEPARTMENTPLUS
This is the reason you should have Renters Insurance. The owners insurance company will pay for all the cleaning and painting of the building, and cleaning any contents the owner may have in there. They may not cover the dry cleaning and laundering of your clothes and cleaning your other belongings (like furniture), computers, and artwork) may not be covered under the owners policy.
I hope he is still around to take that great advice - one and done...EdTheHeaterMan said:
That much soot means CO as well.
2 -
Call fire dept now to verify this is in fact CO accumulation, when you say you notice black soot in house they should respond quickly. ( I would also not stay inside until the conditions are deemed safe. Also, just looked up the tenant landlord contact # in New York city if thats where you are. Dial 311 to contact & they should be able to help get this figured out. BUT! 1st have fire department check it out for safety.1
After reading this closer, I am wondering if its not the propane ?? stove sooting up the kitchen and not the oil boiler. The discoloration above the convector may just be dirt. Either way the poster needs to get fire dept there to find what the problem is. Totally not right and very likely unsafe.1
- 50 Industry Classes
