Purple primer mess
Simply Rad
Member Posts: 200
in Plumbing
I have used clear acetone to get PP out of a concrete floor but it was very fresh. Give it a try in an inconspicuous spot on the HWH tho. That stuff is murder when there’s an accident.0
It’s a nice mech room and it will stick out!
Jeffrey Campbell0 -
Ask @Sherwin Williams!
White spray can paint..0
We all know why they make purple primer. But **** the stuff makes a mess and there is no need for it.0
Is it a metal or plastic jacket
with plastic. Sometimes you can take your pocket knife on edge and scratch it outBob "hot rod" Rohr
You could try acetone, but it will soften the paint in the tank. It works best when if you get it early.
Kilz primer will conceal it. Dust a couple of light coats .
I keep a can on the truck for the occasional splash.0 -
Spray paint..In Future...either tint the Glue with a small amount of Purple Primer to make the inspector happy or just use clear primer and save can to show him. Mad Dog 🐕1
if the shell is metal try lacquer thinner but the dye is intended to not come off to indicate that primer was used. you could probably sand it off of plastic.0
"Gumout" carburetor cleaner0
will try sometime. but i've had very little luck. i'm a clear primer kinda guy.gpjazz said:"Gumout" carburetor cleaner
Gumout is mostly Xylene with some Acetone.
I'd be surprised if it removes the stain without removing paint as well.
PVC primer is mostly MEK and some Acetone and likely melts the paint a little which is why the stain is impossible to remove. The color is literally part of the paint now.
2 -
@Simply Rad
Haven't read through all of the posts so this might have been already suggested.
Use clear primer to clean off the purple. Just dauber it on and wipe it off repeatedly till it's gone.2 -
I like @kcopp's suggestion. Print the maintenance instructions on a 8.5x11 sticker.
https://www.amazon.com/Sheets-Matte-Sticker-Inkjet-Printing/dp/B07T1HRYL5/ref=sr_1_5?crid=39WA7S15TOOL0&keywords=large+white+sticker&qid=1706547130&sprefix=large+white+sticker,aps,147&sr=8-5&th=18.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab1 -
Thanks for all the input. I will let u know what if anything worksJeffrey Campbell0
I would’ve thought by now someone would have made a magic marker in primer color with smell added.Mad Dog_2 said:Just a thin trace of purple...Mad Dog 🐕
2 -
I'm aware of purple sharpies...But does it smell like primer?MikeAmann said:There was an error rendering this rich post.
don't know but it sure tastes good . . .STEVEusaPA said:2 -
Hi @archibald tuttle "don't know but it sure tastes good . . . ". So, what does the doctor say to you after you stick your purple tongue out?
Yours, Larry2 -
I must say. I have not and never will be a fan of purple primer , simply because of that little clever purple marker.
I LOVE IT !! Thank you for sharing this.
Some codes do not require purple primer because clear primer works just as well.
I know, I know it was pushed into a code because of dishonest or naive solvent weld practices.
So I have wondered?
Are some code areas more code compliant and trustworthy than others? Why is it in one code and not the other? Hmm?0 -
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
