Purple primer mess
Simply Rad
Simply Rad Member Posts: 200
I was hooking up the condensate neutralizer on a boiler and I splatted purple primer on the new hot water tank.  Any suggestions on how to get that off?
Thanks Jeffrey
Jeffrey Campbell
Mad Dog_2
  • ferrociousghandi
    ferrociousghandi Member Posts: 4
    I have used clear acetone to get PP out of a concrete floor but it was very fresh. Give it a try in an inconspicuous spot on the HWH tho. That stuff is murder when there’s an accident.
  • Simply Rad
    It’s a nice mech room and it will stick out!
    Jeffrey Campbell
  • kcopp
    kcopp Member Posts: 4,577
    A strategically placed sticker??
    PC7060MikeAmannEdTheHeaterManAlan (California Radiant) Forbes
    EdTheHeaterMan Member Posts: 10,777
    edited January 2024
  • Derheatmeister
    Derheatmeister Member Posts: 1,658
    White spray can paint..
    EBEBRATT-Ed Member Posts: 18,248
    We all know why they make purple primer. But **** the stuff makes a mess and there is no need for it.
    hot_rod Member Posts: 25,357
    Is it a metal or plastic jacket
    with plastic. Sometimes you can take your pocket knife on edge and scratch it out
  • realliveplumber
    realliveplumber Member Posts: 354
    You could try acetone, but it will soften the paint in the tank. It works best when if you get it early.
    Kilz primer will conceal it. Dust a couple of light coats .
    I keep a can on the truck for the occasional splash.
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,898
    o:)
    Yours, Larry
    MikeAmannmattmia2PC7060EdTheHeaterMan
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,269
    Spray paint..In Future...either tint the Glue with a small amount of Purple Primer to make the inspector happy or just use clear primer and save can to show him.  Mad Dog 🐕
    archibald tuttle
  • Mad Dog_2
    Just a thin trace of purple...Mad Dog 🐕
    Intplm.
    Alan (California Radiant) Forbes Member Posts: 4,510
    edited January 2024
    Just leave it there. Kinda' looks like artwork.
    If you mess with it, then it will really look bad.
    SlamDunkGrallert
    mattmia2 Member Posts: 13,511
    if the shell is metal try lacquer thinner but the dye is intended to not come off to indicate that primer was used. you could probably sand it off of plastic.
  • gpjazz
    gpjazz Member Posts: 29
    "Gumout" carburetor cleaner
  • archibald tuttle
    archibald tuttle Member Posts: 1,107
    will try sometime. but i've had very little luck. i'm a clear primer kinda guy.
  • ChrisJ
    ChrisJ Member Posts: 16,853
    Gumout is mostly Xylene with some Acetone.
    I'd be surprised if it removes the stain without removing paint as well.
    PVC primer is mostly MEK and some Acetone and likely melts the paint a little which is why the stain is impossible to remove. The color is literally part of the paint now.
    MikeAmannmattmia2
  • Intplm.
    Intplm. Member Posts: 2,678
    @Simply Rad
    Haven't read through all of the posts so this might have been already suggested.
    Use clear primer to clean off the purple. Just dauber it on and wipe it off repeatedly till it's gone.
    Larry WeingartenZman
    You could just sign the water heater "Jackson Pollok" and maybe increase its value by a couple of thousand dollars.
    Intplm.MikeAmannCLambMad Dog_2
  • 8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
    MikeAmann
  • Simply Rad
    Thanks for all the input.  I will let u know what if anything works
    Jeffrey Campbell
  • STEVEusaPA
    I would’ve thought by now someone would have made a magic marker in primer color with smell added.
    EdTheHeaterManMad Dog_2
  • STEVEusaPA
    MikeAmann said:
    I'm aware of purple sharpies...But does it smell like primer?
  • archibald tuttle
    don't know but it sure tastes good . . .
  • dko
    dko Member Posts: 668
    :o
  • Larry Weingarten
    Hi @archibald tuttle "don't know but it sure tastes good . . . ". So, what does the doctor say to you after you stick your purple tongue out? :p
    Yours, Larry
    Intplm.Mad Dog_2
  • Intplm.
    edited January 2024
    I must say. I have not and never will be a fan of purple primer , simply because of that little clever purple marker.
    I LOVE IT !! Thank you for sharing this.
    Some codes do not require purple primer because clear primer works just as well.
    I know, I know it was pushed into a code because of dishonest or naive solvent weld practices.
    So I have wondered?
    Are some code areas more code compliant and trustworthy than others? Why is it in one code and not the other? Hmm?
  • Mad Dog_2
    "All politics is local."  Territorialism, et cetera.  Mad Dog 🐕
    mattmia2Intplm.
