Snowmelt timelapse
It’s a little better than nothing🤫 Not much you can do to improvejamplumb said:Hey Hot Rod, what do you think of the underslab insulation? My understanding is that the bubble stuff is not that good.
some edge insulation could help, but it is tricky to detail that and hide the edge
A 45 bevel on 2” foam us one methodBob "hot rod" Rohr
Hot Rod do you think insulating my heat exchanger would make a big difference?
Probably not a huge difference. It may keep it from dripping condensation when cold glycol hits it.jamplumb said:Hey Hot Rod, what do you think of the underslab insulation? My understanding is that the bubble stuff is not that good.
Some manufacturers have foam insulation jackets that fit perfectly. Or whittle one out of some rigid foamboard.Bob "hot rod" Rohr
A sheet of Armaflex™ can be used with good effect. That's what I did, & it looked pretty nice.0
