Snowmelt timelapse
2»
    hot_rod Member Posts: 26,548
    jamplumb said:
    Hey Hot Rod, what do you think of the underslab insulation? My understanding is that the bubble stuff is not that good.
    It’s a little better than nothing🤫 Not much you can do to improve
    some edge insulation could help, but it is tricky to detail that and hide the edge
    A 45 bevel on 2” foam us one method
  • Burnett03
    Burnett03 Member Posts: 28
    edited January 2024
    Hot Rod do you think insulating my heat exchanger would make a big difference?
    Probably not a huge difference. It may keep it from dripping condensation when cold glycol hits it.
    Some manufacturers have foam insulation jackets that fit perfectly. Or whittle one out of some rigid foamboard.
  • ratio
    ratio Member Posts: 4,176
    A sheet of Armaflex™ can be used with good effect. That's what I did, & it looked pretty nice.
