Simplest way to test a rad
Tommi68
Member Posts: 52
Before I swap in a used rad from my storage, how do you all pressure test yours? I have no documentation on the replacement rad in question, so I am not certain why it was removed from service. It probably became surplus during a renovation but I would like some certainty. It is a 6 element, two pipe rad with no bleed, so I don't think I can water test it.
What do you do?
What do you do?
Never done it, but I'd test it like a gas line, air pressure with a gauge and ball valve to lock it off. Put in 60psi and see if it leaks out.0
A hydrostatic test with water would be the safest way to do this. Testing an unknown vessel with air could be very dangerous if a section were to break away.0
It would be best to replace with New , cheaper then surplus ....
This.TomS said:A hydrostatic test with water would be the safest way to do this. Testing an unknown vessel with air could be very dangerous if a section were to break away.
Consulting1 -
If it has openings, you can get water into it. And out of it. Use water, as said at not over 30 if it's to be a hot water radiator, 15 psi for steam.
Do NOT use compressed air! Do you have any idea how far the shrapnel would go if it broke at 60 psi?Br. Jamie, osb
Thanks for the advice. The rad is small enough to lay on its side to vent trapped air.I am presuming that I will fill it with water then add a small volume of compressed air to reduce the capacity for a catastrophic failure.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
