Simplest way to test a rad
Tommi68
Tommi68 Member Posts: 56
Before I swap in a used rad from my storage, how do you all pressure test yours? I have no documentation on the replacement rad in question, so I am not certain why it was removed from service. It probably became surplus during a renovation but I would like some certainty. It is a 6 element, two pipe rad with no bleed, so I don't think I can water test it.
What do you do?
  • Jells
    Jells Member Posts: 649
    Never done it, but I'd test it like a gas line, air pressure with a gauge and ball valve to lock it off. Put in 60psi and see if it leaks out.
  • TomS
    TomS Member Posts: 66
    A hydrostatic test with water would be the safest way to do this. Testing an unknown vessel with air could be very dangerous if a section were to break away.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    It would be best to replace with New , cheaper then surplus ....
    EBEBRATT-Ed Member Posts: 20,140
    There is no reason you can't test with water. I would not go over 30psi.
    If you can't vent the air out due to no bleeder turn the rad upside down.
    Tommi68
    Steamhead Member Posts: 18,453
    This.
    Consulting
    Tommi68
    Jamie Hall Member Posts: 27,312
    If it has openings, you can get water into it. And out of it. Use water, as said at not over 30 if it's to be a hot water radiator, 15 psi for steam.
    Do NOT use compressed air! Do you have any idea how far the shrapnel would go if it broke at 60 psi?
  • Jells
    You're right, I wasn't thinking.
  • Tommi68
    Thanks for the advice. The rad is small enough to lay on its side to vent trapped air.
    I am presuming that I will fill it with water then add a small volume of compressed air to reduce the capacity for a catastrophic failure.
