Thread sealant cure
Dave_61
Member Posts: 316
in Oil Heating
I see that Gasoila is specified for oil line fittings. It says cure time is 24 hours. But what do you do in the wintertime when boiler needs to run? How long is adequate cure time? Thanks
Makes sense. Thanksrealliveplumber said:The cure time is as short as you need it to be to get the heat on. The sealant is in the root of the threads.If the threads dont leak, the oil cant get to where the sealant is.1 -
Cure time, I'll need to ask my daughter, She is a Doctor.
But seriously, the time it takes to put the sealant on the threads, twist the fitting into the pump or filter or heaven forbid, tiger loop, and connect the copper tubing is all I ever waited before I turned on the burner. I allow the curing time to take place while the burner is operating.
Anyone else wait 24 hours for pipe dope?Edward Young Retired
At Union rates?EdTheHeaterMan said:Cure time, I'll need to ask my daughter, She is a Doctor. But seriously, the time it takes to put the sealant on the threads, twist the fitting into the pump or filter or heaven forbid, tiger loop, and connect the copper tubing is all I ever waited before I turned on the burner. I allow the curing time to take place while the burner is operating. Anyone else wait 24 hours for pipe dope?0 -
There is a hard set version that needs a cure time. Ive never seen on shelvesBob "hot rod" Rohr
I've been tempted to mix up some expando and try it out. Rumor on the streets is it's impossible to get back apart.EBEBRATT-Ed said:Only when using "Expando" on a high-pressure oil line that ran at like 400 deg.
I recommend using hydraulic Loctite. I have been using it on #2 diesel for years and it NEVER leaks! If anyone tells you it won't come apart, don't believe them, just tell them to go to the gym.0
@ChrisJ
I only used it twice (Expando) and I never had to take an Expando apart. They say on Expando website to have 2 people and put some pressure on the joint with a pipe wrench as if to loosen it then have the other guy tap the fitting all the way around with a hammer.1 -
Put it together and turn it on. Tightened up properly, you will have NO issues.0
I really hate pipe dope questions.
There are no answers except making sure the dope you use is compatible with the type of pipe and the contents of the pipe.
Every poster has a method that works for them.
Why discuss the endless question of what dope to use, how to apply it, weather to use it with Teflon tape or is Blue Monster tape better?. Do you dope the fitting before taping with teflon or do you use the dope first or do you dope tape then dope? What if I use dope with no tape? How about doping the inside of the female threads? etc etc etc?
It's like installing a boiler. We always say the installer is more important than the boiler. Well, the installer is more important than the dope....unless the installer is the dope.
My Sunday rant. Not going to respond to dopey questions anymore
4 -
Yes you are and you know it.EBEBRATT-Ed said:I really hate pipe dope questions. There are no answers except making sure the dope you use is compatible with the type of pipe and the contents of the pipe. Every poster has a method that works for them. Why discuss the endless question of what dope to use, how to apply it, weather to use it with Teflon tape or is Blue Monster tape better?. Do you dope the fitting before taping with teflon or do you use the dope first or do you dope tape then dope? What if I use dope with no tape? How about doping the inside of the female threads? etc etc etc? It's like installing a boiler. We always say the installer is more important than the boiler. Well, the installer is more important than the dope....unless the installer is the dope. My Sunday rant. Not going to respond to dopey questions anymore
2 -
