Furnace Replacement
Eweneek1
Eweneek1 Member Posts: 4
edited January 2024 in THE MAIN WALL
Need to replace a 30 year old Payne 115,000 BTU furnace. I only need heat, no A/C. Which brands should I consider? Would like two stage with ECM and high efficient heating. Mounting horizontal.
  • Ironman
    Ironman Member Posts: 7,766
    Trane/Amer.Std uses stainless steel in both primary and secondary heat exchangers.
    However, the installer is 95% of the equation, not the brand.
    Bob Boan
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,224
    I’d figure out the heat loss first. How much gas do you use per year?
    pecmsg Member Posts: 6,526
    Do NOT replace like size for like size. Get a actual heat loss performed.
    The names on the trucks are more important than the names on the boxs!
    GGross
