Furnace Replacement
Eweneek1
Member Posts: 4
Need to replace a 30 year old Payne 115,000 BTU furnace. I only need heat, no A/C. Which brands should I consider? Would like two stage with ECM and high efficient heating. Mounting horizontal.
Trane/Amer.Std uses stainless steel in both primary and secondary heat exchangers.
However, the installer is 95% of the equation, not the brand.Bob Boan
I’d figure out the heat loss first. How much gas do you use per year?0
- 87.5K THE MAIN WALL
- 119 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
