Boiler humming sound in the walls
Maybe someone can help me with this noise.
I have a boiler system for my heat of course with baseboards . Recently we started hearing a loud humming through the walls when the heat would click on and stop obviously when the heat clicks off. When we went to the boiler we found out the damper vent was stuck in an open position and they said tht would stop the sound since it sounded like tht was where the humming was coming from …we changed the damper we still have the sound happening …no one can tell me what it can be …..maybe some experts on here can give me a clue …
Thank you in advance and happy new year …
Please edit your post to remove the amount you were robbed. And call them up and ask them to credit you since they didn't fix the problem.
If the noise started recently, and there were NO changes made to the system or its vents or the flue or otherwise, it's not likely to be associated with the vent and flue. It is more likely that something in the piping shifter very slightly in such a way that the vibration for the circulating pump or the vibration from the burner or its pump (is this oil?) is being transmitted into the house structure. This can be really hard to find, but anywhere that a pipe is firmly attached to or firmly touching a part of the structure is a possibility.Br. Jamie, osb
What type of circulator pump?The 3 piece can develop noise if the coupling or motor mounts are failing.Bob "hot rod" Rohr
Not sure what the circular pump is …but sometimes when I held the damper vent the sound would decrease but idk….heres the pic of my system.0 -
Often when I come across a problem like this, a pipe or component is rubbing up against something causing a vibration noise that reverberates throughout the house.
Turn the heat up make the boiler turn on and while it is running, gently push on pipes and anything else that may be a little loose. Someone may have possibly brushed up against something while working on the boiler causing this noise.0 -
in ours the Carlin Motor Pump needed to be adjusted. Our chimney is very old. When the pump was set to factory settings it was whomping like a jet was in the chimney, the house sounded like it was vibrating with wind. The tech called Carlin, they told him how to adjust the air. They also told him about a type of nozzle to use. Now it’s quiet. Love, love, love the Carlin company!
- 120 Geothermal
