Humidity Control with Radiant Floor Heat
smiller69
Member Posts: 2
How do you humidify and dehumidify when heating with in-slab hot water radiant heat. Will be building a slab-on-grade house.
You will need to use an independent humidifier or dehumidifier, as the case may be.Br. Jamie, osb
I typically deal with Aprilaire. Their dehumidifiers can be ducted, and their steam Humidifier offers a fan pack if you don't have existing ductwork.0
