Humidity Control with Radiant Floor Heat
How do you humidify and dehumidify when heating with in-slab hot water radiant heat.  Will be building a slab-on-grade house.
    Jamie Hall Member Posts: 27,574
    You will need to use an independent humidifier or dehumidifier, as the case may be.
    HVACNUT Member Posts: 7,523
    I typically deal with Aprilaire. Their dehumidifiers can be ducted, and their steam Humidifier offers a fan pack if you don't have existing ductwork.
    pecmsg Member Posts: 7,273
    What’s the A/C? That should cover 90% of your dehumidification.
    In the winter you will need moisture.
