Rust on Brand New Burnham Boiler
Boilertrouble
Member Posts: 14
in Oil Heating
I had a brand new Burnham Boiler installed a few weeks ago. Didn’t think to inspect the underside of the boiler during the install, but recently noticed a huge amount of rust underneath it.
Based on the photos below, should I be concerned? Burnham said it’s probably just surface rust, no big deal. As a non-expert, it seems very concerning.
Ironman said:
Just surface rust. Perfectly normal.
This.bburd said:There is no need to worry about this, it is entirely normal and insignificant. Cast-iron is tough stuff.
Consulting0 -
Keep in mind..the cast Iron is very thick. Go get some spiked eggnog or Coquito and Hug the Grandkids! Mad Dog 🐕1
I have put in a zillion cast iron boilers and almost all of them look like that somewhere or other0
Don’t worry, it’s going to rot from the inside out 😅
Completely normal. Scrub a Cast Iron pan and put it on the counter to air dry without drying it and it will look just like the boiler.0
- 110 Chimneys & Flues
- 982 Plumbing
- 387 Solar
