Grundfos 3 phase pump for my snowmelt system??
asmedley
Member Posts: 1
So I recently poured a sidewalk from the street to my new basement apartment with 2 240’ loops of 3/4” pex. A couple weeks ago I acquired a Grundfos 3 phase pump that I have been trying to figure out if it’s worth it to try and make work for my snowmelt system. Is it even possible/worth it where I only have single phase? Is it overkill for my system? I will put a link to the pump I found that has all the specs. Any help would be much appreciated. Thanks!
https://www.mrosupply.com/pumps/5027468_96654375_grundfos/
Even if you could get 3 phase, that’s way too much pump.
Sell it here or on eBay.Bob Boan
One phase to three phase converters do exist. They aren't cheap. To put it mildly. You can probably buy two or three decent standard pumps suitable for what you want for the cost of an inverter.
Sell the three phase, or they make good paperweights...Br. Jamie, osb
You need 4-5 gpm max. Get a better sized pumpBob "hot rod" Rohr
Living the hydronic dream0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
