Grundfos 3 phase pump for my snowmelt system??
So I recently poured a sidewalk from the street to my new basement apartment with 2 240’ loops of 3/4” pex. A couple weeks ago I acquired a Grundfos 3 phase pump that I have been trying to figure out if it’s worth it to try and make work for my snowmelt system. Is it even possible/worth it where I only have single phase? Is it overkill for my system? I will put a link to the pump I found that has all the specs.  Any help would be much appreciated. Thanks!
https://www.mrosupply.com/pumps/5027468_96654375_grundfos/
  • Ironman
    Ironman Member Posts: 7,918
    Even if you could get 3 phase, that’s way too much pump.
    Sell it here or on eBay.
    Bob Boan
    Jamie Hall Member Posts: 27,516
    One phase to three phase converters do exist. They aren't cheap. To put it mildly. You can probably buy two or three decent standard pumps suitable for what you want for the cost of an inverter.
    Sell the three phase, or they make good paperweights...
    109A_5 Member Posts: 4,158
    edited December 2023
    Hello @asmedley,
    If the building does not already have 3 phase power it is probably not worth it. And it is probably too much pump anyways.
    hot_rod Member Posts: 27,707
    You need 4-5 gpm max. Get a better sized pump
