Low pressure gauge
I found a really good one on Amazon, it even has other ranges, all the way down to 0-15 inches of water column, let me get the link:
https://www.amazon.com/dp/B0869BP5CF
It also has zeroing and it's a good priceNJ Steam Homeowner.
I always liked a combination gauge to show vacuum also. Nothing like that seems to exist in the range 0-3 PSI, I think 0-15 PSI with vacuum was the lowest range i ever found.0
Cheap 0-3PSI made in China:
https://www.amazon.com/gp/product/B00H9ZWLZG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Seems to be accurate, can be rezeroed. You want to protect it with a shut off valve before it.
Top of the line American made:
https://dwyer-inst.com/en/series-magnehelic-2000.html
Scroll down to 2203 for 0-3PSI, the more accurate (more divisions on the pressure scale) 0-2 and 0-1 PSI gauges are 2202 and 2201.
Basically bulletproof pressure wise because these gauges will take 15psi before failing.0 -
They don’t even fail. They have a pop off plug that goes first.
you can get them NOS or used on eBay for $20 sometimesNJ Steam Homeowner.
Always used wika just ordered some cheap ones can’t hurt 1 wika
Interesting but the Dwyers have a max temp of 140°f on the cover. Assuming not good for measuring steam?Waher said:Cheap 0-3PSI made in China: https://www.amazon.com/gp/product/B00H9ZWLZG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Seems to be accurate, can be rezeroed. You want to protect it with a shut off valve before it. Top of the line American made: https://dwyer-inst.com/en/series-magnehelic-2000.html Scroll down to 2203 for 0-3PSI, the more accurate (more divisions on the pressure scale) 0-2 and 0-1 PSI gauges are 2202 and 2201. Basically bulletproof pressure wise because these gauges will take 15psi before failing.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
I always put a valve on anyway and leave it turned off. I only use it to check the pressure when I’m there too many supers and handyman changeing the pressure and damage the gauge..0
There is a cushion of air in the pipe below the gauge. Unless you put a radiator vent on the gauge, the steam won't get to it, depending on length and size of pipe.guzzinerd said:
Interesting but the Dwyers have a max temp of 140°f on the cover. Assuming not good for measuring steam?NJ Steam Homeowner.
Thanks. My gauge is off a t with the pressuretrol above the pigtail. Ok to mount there ? I do have a shut-off to the gauge.ethicalpaul said:Interesting but the Dwyers have a max temp of 140°f on the cover. Assuming not good for measuring steam?
There is a cushion of air in the pipe below the gauge. Unless you put a radiator vent on the gauge, the steam won't get to it, depending on length and size of pipe.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Sounds good. With a valve below the gauge you're going to be fine
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
