Low pressure gauge
Where are you guys buying your 3 pound gauges right now can’t seem to find anything. I have not purchased any in a few years.
    Jamie Hall Member Posts: 27,486
    Don't tell... Amazon...
    ethicalpaul Member Posts: 8,916
    edited November 2023
    I found a really good one on Amazon, it even has other ranges, all the way down to 0-15 inches of water column, let me get the link:
    https://www.amazon.com/dp/B0869BP5CF
    It also has zeroing and it's a good price
  • Dan_NJ
    Dan_NJ Member Posts: 268
    I always liked a combination gauge to show vacuum also. Nothing like that seems to exist in the range 0-3 PSI, I think 0-15 PSI with vacuum was the lowest range i ever found.
  • Waher
    Waher Member Posts: 373
    Cheap 0-3PSI made in China:
    https://www.amazon.com/gp/product/B00H9ZWLZG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
    Seems to be accurate, can be rezeroed. You want to protect it with a shut off valve before it.
    Top of the line American made:
    https://dwyer-inst.com/en/series-magnehelic-2000.html
    Scroll down to 2203 for 0-3PSI, the more accurate (more divisions on the pressure scale) 0-2 and 0-1 PSI gauges are 2202 and 2201.
    Basically bulletproof pressure wise because these gauges will take 15psi before failing.
    They don’t even fail. They have a pop off plug that goes first.
    you can get them NOS or used on eBay for $20 sometimes
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,616
    Wika...online search  Gkod quality so far   mad Dog 🐕
  • Steve_210
    Steve_210 Member Posts: 664
    Always used wika just ordered some cheap ones can’t hurt 1 wika
  • guzzinerd
    guzzinerd Member Posts: 461
    Waher said:
    Cheap 0-3PSI made in China: https://www.amazon.com/gp/product/B00H9ZWLZG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1 Seems to be accurate, can be rezeroed. You want to protect it with a shut off valve before it. Top of the line American made: https://dwyer-inst.com/en/series-magnehelic-2000.html Scroll down to 2203 for 0-3PSI, the more accurate (more divisions on the pressure scale) 0-2 and 0-1 PSI gauges are 2202 and 2201. Basically bulletproof pressure wise because these gauges will take 15psi before failing.
    Interesting but the Dwyers have a max temp of 140°f on the cover.   Assuming not good for measuring steam?
    Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
  • Steve_210
    I always put a valve on anyway and leave it turned off. I only use it to check the pressure when I’m there too many supers and handyman changeing the pressure and damage the gauge..
    There is a cushion of air in the pipe below the gauge. Unless you put a radiator vent on the gauge, the steam won't get to it, depending on length and size of pipe.
  • guzzinerd
    Thanks.  My gauge is off a t with the pressuretrol above the pigtail.  Ok to mount there ?  I do have a shut-off to the gauge.
    Sounds good. With a valve below the gauge you're going to be fine
    guzzinerd
  • Waher
    All of the low pressure gauges need to be protected with a pigtail or a tall enough nipple above the water line to create an air gap so that steam never reaches the gauge.
    guzzinerd
