Need steam pro in Northern NJ
HeatingHelp
Administrator Posts: 710
This discussion was created from comments split from: Help Balancing Steam System.
Hello. I'm having balancing issues. Please recommend a steam pro contractor in Northern New Jersey (Essex County). Thanks.0
@alang7, welcome to Heating Help! I've created a new discussion so that your post doesn't get lost at the bottom of that older thread.
You can find a steam pro here: https://heatinghelp.com/find-a-contractor/President
HeatingHelp.com0 -
You might have trouble finding a good one to help you with that...they are likely all too busy installing boilers, but maybe not! Maybe one will reply here.
But also search the site because there are hundreds of threads talking about every kind of balancing issue and it's often not that hard to improve things yourself. Also look into this book by the founder of this very site: https://heatinghelp.com/store/detail/we-got-steam-heat-a-homeowners-guide-to-peaceful-coexistenceNJ Steam Homeowner.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
