No Pride...shoddy...not too safe either
Mad Dog_2
Member Posts: 8,539
This was in a NJ Rest Stop somewhere on Route 17 . This is supposed to be ADA compliant and Handicap accessible!! A wheelchair bound person could bump thaf waste pipe and get a Bath on their legs and lap. They might also snag the Hot water flex, panick and yank it off the valve and Scald themselves..
I HOPE a Plumbing inspector didn't ok this and that it was done without inspection! Disheartening 😔...Mad Dog 🐕1 -
What’s the black battery powered gizmo?0
Blue stripe flex is cold, red stripe flex is hot. What's the problem...lmao.
Look at the lath and plaster behind that eschutcheon.
Thanks for the insight @Mad Dog_2, Perhaps I could stop by there in my wheelchair and do just that. Big payday for me. The guy in the wheelchair always wins in a jury trial.
2 -
not a safe assumption, sadlydko said:I too look at the plumbing everywhere I go haha
When it looks like that, I usually assume it's the work of the business owner/homeowner.NJ Steam Homeowner.
Probably a proximity activation mechanism (I don't know the industry name) to turn the water on when you put your hand under the faucetPC7060 said:What’s the black battery powered gizmo?
Box is for batteries and circuit board for sensor faucet. Thermostatic mixing valve, Max water temp 110. Is next to it0
- 50 Industry Classes
