Crack in cap to an old steam pipe concern
Alexnyu10
Member Posts: 39
dear group,
this year we had one of the radiators removed from our upstairs because the room was always hot even with the radiator turned fully off (enough heat easily rose from main level to heat it (this is a single pipe steam system in a residential home) and we had the old radiator pipe capped on the main level where the pipe used to go up to second floor.
I noticed this morning that the cap has a crack forming on it, and I’m trying to figure out if this is normal or am “oh ****” moment that requires a plumber sooner than later.
Thanks so much for your guidance as always, I plan to message my plumber a pic tomorrow as well but figured I would ask here today to see if it’s urgent enough for a weekend call.
Thats extremely odd. Malleable black Iron will rarely split like that unless it's on a seam. Cast Iron will do that. I wouldn't be super concerned. Just throw a bucket over it until he comes. Mad Dog 🐕0
Ed you may be right. My spouse is also convinced it’s a casting seam and was always like that; so maybe I am jumping the gun and it’s actually always looked this way. Either way I’m going to work on getting mad dog 2 out here to assess my system.EdTheHeaterMan said:Is that a crack or a casting seam?0 -
Very much appreciate everyone’s help here, incredible peace of mind, I love this forum!0
I'm going with a crack. Look at the side of the cap..Little hunk out of it. Mad Dog 🐕0
Don't you think that is getting a little personalWMno57 said:Hmm, hard to tell from here. Drag a fingernail over it. Run a file over it. Is it an innie or an outie?
I prefer the innies personally, Just saying, since you mentioned itEdward Young Retired
3 -
Casting seam.
- 50 Industry Classes
