New Burnham steam boiler only heats fully in the morning
HVAC1301
Member Posts: 1
New Burnham steam boiler only heats fully in the morning. Out of a five steam radiator system only three get heat, but in the morning all 5 get heat. All the valves are open. Placing new Vents on steam radiators? The boiler installation included a new automatic water fill mechanism for Burnham (did not have one before)...HOT in the morning all 5 steam radiators, but only in morning.
The thermostat question is important. Some thermostats -- in fact almost all moder ones -- come factory set for forced air heat. Which isn't correct. They also come with a manual which will explain how to set them for steam...Br. Jamie, osb
This. Also, measure the length and diameter of your mains- we can tell you what you need.bburd said:What kind of main vents do you have? These are located at the end of the steam mains, which may be near the boiler before they drop down near the floor. Pictures would be helpful.All Steamed Up, Inc.
Consulting0 -
Don't focus on the system getting "fully hot". It rarely should. Focus on if you have rooms where those radiators aren't keeping the room warm. This will help focus you on what needs to be done to balance the system. As others said, your main venting is worth a look.
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 117 Geothermal
