New Burnham steam boiler only heats fully in the morning
New Burnham steam boiler only heats fully in the morning. Out of a five steam radiator system only three get heat, but in the morning all 5 get heat. All the valves are open. Placing new Vents on steam radiators? The boiler installation included a new automatic water fill mechanism for Burnham (did not have one before)...HOT in the morning all 5 steam radiators, but only in morning.
  • bburd
    bburd Member Posts: 1,305
    edited November 2023
    What kind of main vents do you have? These are located at the end of the steam mains, which may be near the boiler before they drop down near the floor. Pictures would be helpful.
    What kind of thermostat do you have? Make and model?
    Bburd
    Mad Dog_2
    Jamie Hall Member Posts: 27,396
    The thermostat question is important. Some thermostats -- in fact almost all moder ones -- come factory set for forced air heat. Which isn't correct. They also come with a manual which will explain how to set them for steam...
    Steamhead Member Posts: 18,527
    This. Also, measure the length and diameter of your mains- we can tell you what you need.
    Consulting
  • hilltown
    hilltown Member Posts: 76
    Perhaps they all get hot only in the morning, because the thermostat is turned up from a low nighttime setback temp and has a longer run time than during the day when it is just maintaining. It seems like venting can be an issue, are the radiator vents adjustable?
    OilfieldHippieethicalpaulTwoTones
    ethicalpaul Member Posts: 8,863
    Don't focus on the system getting "fully hot". It rarely should. Focus on if you have rooms where those radiators aren't keeping the room warm. This will help focus you on what needs to be done to balance the system. As others said, your main venting is worth a look.
