One rad heats up before the others can.
Frankfog2
Member Posts: 44
The small white radiator is an outlier compared to the rest of them, i have 7 radiators, all of them are like the first one except this one. The little white one has a #4 mid o mist vent, but it heats up instantaneously. The other ones take roughly 30 minutes to get heat from one end to the other. Does anyone have a recommendation to slow the heat down on this rad?
Install a smaller vent on that radiator...
Get a Ventrite #1 adjustable. Probably the best vent for low venting control.0
dabrakeman said:Get a Ventrite #1 adjustable. Probably the best vent for low venting control.0
Is the small radiator one of the first ones on the line? Do you have adequate main venting in the basement?2
This.KC_Jones said:Is the small radiator one of the first ones on the line? Do you have adequate main venting in the basement?
Consulting3 -
Yeah check the main venting. Don’t waste time or money trying to go smaller than a #4
See my sight glass boiler videos: https://bit.ly/3sZW1el1
- 111 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
