One rad heats up before the others can.
The small white radiator is an outlier compared to the rest of them, i have 7 radiators, all of them are like the first one except this one. The little white one has a #4 mid o mist vent, but it heats up instantaneously. The other ones take roughly 30 minutes to get heat from one end to the other. Does anyone have a recommendation to slow the heat down on this rad?
  • Big Ed_4
    Big Ed_4 Member Posts: 3,551
    Install a smaller vent on that radiator...
  • Frankfog2
    Frankfog2 Member Posts: 44
    what do you recommend? I thought a #4 is the lowest it’ll go
  • dabrakeman
    dabrakeman Member Posts: 1,020
    Get a Ventrite #1 adjustable.  Probably the best vent for low venting control.
  • Frankfog2
    Will do, thanks
  • KC_Jones
    KC_Jones Member Posts: 5,939
    Is the small radiator one of the first ones on the line? Do you have adequate main venting in the basement?
    2014 Weil Mclain EG-40
    mattmia2ethicalpaul
    Steamhead Member Posts: 18,714
    This.
    Consulting
    bburdmattmia2ethicalpaul
    ethicalpaul Member Posts: 8,933
    Yeah check the main venting. Don’t waste time or money trying to go smaller than a #4
    BobC
