Need suggestion for a small, superior sump pump
Little Giants are not lasting more than a year. This is regular groundwater. This basement has major groundwater problems but when these pumps work the 6 - 8" Round, 10" pits keep the basement dry. Anybody have a more durable brand? The key is it can't be very wide and needs a built in float switch. Thanks Guys Mad Dog0
I have one of those pumps in a custom sink in the shop that's been handling sink water for 3 years now and we have another handling ground water. I've used them in other applications for customers as well
The only time I've had issues with that model pump is when someone installed them with a check valve without drilling an air bleed valve.
The pressure switch can also get plugged in the tiny hole that lets water into the switch.
I've also found one with the vent to the switch packed with mud.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Liberty still builds big motor cast iron sump pumps, a NY companyBob "hot rod" Rohr
Living the hydronic dream2 -
Here's the holes I'm talking about on Little Giant's pressure activated switch.
The small one on the plug end is the vent.
Inside the actual switch housing is just a diaphragm that pushes against a switch.
I would use something like https://www.hydrocheckproducts.com/product-page/hc6000-hi-low-sump-controller-dual-float
so you now have many more choices of manual pumps to choose from since you don't have the account for float dimensions.1 -
Sears was selling something like that in the late 1970s-early 80s.dko said:I would use something like https://www.hydrocheckproducts.com/product-page/hc6000-hi-low-sump-controller-dual-float
I never heard anything about it really so I assumed it was something that didn't really work great. Do you have experience with them and real world use?
Hello Matt,
If you have a 4-5 gallon round pail all you need to do is drill 1/4" holes in it 2 inches apart all the way around and down to the base to protect the pump and place the pump on a brick and your pump will last much, much longer and not be plugged with silt.
We used the New York state made liberty pumps for years to dry out the rear 12 acres of my fathers old property.
Don't want to punch through the slab because it was a special engineered design and there are very active springs underneath. I did find a skinny pump only
7 1/2"s wide.. Pro Series ? The water is not gushing in...its a slow overnight infiltration, so I don't think its short cycling. Mad Dog ๐3 -
Mad Dog_2 said:Don't want to punch through the slab because it was a special engineered design and there are very active springs underneath. I did find a skinny pump only
7 1/2"s wide.. Pro Series ? The water is not gushing in...itโs a slow overnight infiltration, so I don't think itโs short cycling. Mad Dog ๐0 -
mattmia2 said:I've never had to babysit a sump pump but a zoeller pump came sitting in the basement with my house and it looks to be of superior construction.
Little Giant has plenty of expensive pumps that are very well made, no less than Zoeller in my opinion
I like Little Giant, but Zoeller is the Gold Standard around here. Mad dog ๐
SlamDunk said:Zoeller. Hands down. I just replaced a ten year old one at home and bought a new float switch for the one that failed. Keep it as a back up. I installed one at work, in 2009,that pumps soapy hot water out of a pit. Still running.
10 years doesn't seem very impressive.
That used two weights on a cable and the switch drove a relay.
I think it was rated 50 gpm @ 20'
The house I grew up in had a 1964 Sears Homart pump in one of the two pits still running fine in 2006.ChrisJ said:
Where can I get one?0 -
but the 1964 sears was a pedestal pump, right?0
mattmia2 said:but the 1964 sears was a pedestal pump, right?
Same as $540 today for a half horse.
It was also the quietest pump I've ever seen.... Or heard I guess.
Their Flex -O-pipe was black polyethylene. Ours still had the original setup.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
interesting that the catalog numbers are different than the model numbers0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
